Posted July 15, 200816 yr comment_253694 Quick question. Is it possible to have:260 base engine280z crankshaftE88 head???Or the opposite?240Z base engine280Z crankshaft260 head???I spoke with the previous owner on my 240Z who was in California.. Does that make sense??? Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/ Share on other sites More sharing options...
July 15, 200816 yr comment_253697 A stock L26 has the same stroke as a L28 and is basically a L24 stroker. Basically, an L26 with a L28 crank would be an L26. An L24 with a L28 crankshaft would be an L26. I hope I said that right but here is the stock bore and stroke of each:L24-83x73.7L26-83x79L28-86x79 Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/#findComment-253697 Share on other sites More sharing options...
July 15, 200816 yr Author comment_253706 So in term of performance, what would that give??I know for sure high compression, but what else?? Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/#findComment-253706 Share on other sites More sharing options...
July 15, 200816 yr comment_253716 Niether of those two combinations you list would be any different than a stock L26.1) 260 base engine, 280z crankshaft, E88 head: That's basically what the factory did. The 260 and 280 crank are the same thing as are the rods. and you'd use 260 pistons in this combo. Well, that's exactly how the factory built them.2) 240Z base engine, 280Z crankshaft, 260 head: Well, if you think about that, that is also basically what the factory did. An L24 block would need the L26 pistons and L26/28 rods to run a L28 crank. A 260 head is an E88. Both scenarios are the same as a factory built stock L26 with a displacement of 2565 cc amd a compression ratio of 8.29-1. So there would be actually no need to go out of your way to put together either of those combinations since Nissan already did it about 35 years ago. Basically what I'm trying to say is that an L26 is an L24 with L26 pistons and L26/L28 crank and rods. Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/#findComment-253716 Share on other sites More sharing options...
July 16, 200816 yr Author comment_253731 OK, I spoke with the previous owner and he told that's what he put in the car..Just trying to figure out, more HP maybe??? Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/#findComment-253731 Share on other sites More sharing options...
July 16, 200816 yr comment_253745 Actually, no. If you used stock parts in either of the combinations you mentioned, what you would have is basically a stock L26. Link to comment https://www.classiczcars.com/forums/topic/28745-260z-engine-combo/#findComment-253745 Share on other sites More sharing options...
