Posted July 26, 200816 yr comment_254444 I have a 260z, and when I use the brakes it will blow the fuse or ture on the flasher it will blow the fuse what could this be ? Link to comment https://www.classiczcars.com/forums/topic/28824-260z-brake-lights-blows-fuse/ Share on other sites More sharing options...
July 26, 200816 yr comment_254446 Is the car new (to you) or is this something that just started happening? Did you recently change or replace the brake light bulbs? Without knowing the history, all I can say is that it sounds like you have a short in the brake light system somewhere (I think you already knew that!) and about all you can do is track through the circuit until you find it. Remove one brake light bulb and then try it and then the other if that doesn't work. Make sure you have dual filament, dual contact bulbs in those sockets and that the sockets themselves are in good condition. That will confirm or elminate the bulbs/sockets as the problem. Link to comment https://www.classiczcars.com/forums/topic/28824-260z-brake-lights-blows-fuse/#findComment-254446 Share on other sites More sharing options...
July 26, 200816 yr Author comment_254473 The car is fixed now I found where a shop did a hack job so I had to fix it wright .Thanks Link to comment https://www.classiczcars.com/forums/topic/28824-260z-brake-lights-blows-fuse/#findComment-254473 Share on other sites More sharing options...
