Posted July 27, 200816 yr comment_254586 I have checked my timing and at 700 to 800 rpm, I am sitting at about 7 Degrees of advance. Is this right? Also, just a note, at 2800 rpm, I am at 44 degrees. How does this stack up to what it should be? Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/ Share on other sites More sharing options...
July 27, 200816 yr comment_254597 Stock is 5 degrees, but total advance is not in the 40s. It is generally agreed that a total of 36 degrees is optimum. You are getting too much total advance. Most early Zs can be set up to 12 degrees at idle to get a total of 36 degees. Maybe someone recurved your distributor. Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/#findComment-254597 Share on other sites More sharing options...
July 28, 200816 yr Author comment_254624 Okay, I dont think I was completely clear with my situation, my apologies. Its been a long time since I had to do timing on an old car, my trans am ran a mechanical advance MSD distributer. When you check the timing, are you suppose to disconnect the vacuum advance? Gosh I feel like a moron for asking that! Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/#findComment-254624 Share on other sites More sharing options...
July 28, 200816 yr comment_254635 Zedyone_kenobi said: Okay, I dont think I was completely clear with my situation, my apologies. Its been a long time since I had to do timing on an old car, my trans am ran a mechanical advance MSD distributer. When you check the timing, are you suppose to disconnect the vacuum advance? Gosh I feel like a moron for asking that! Yes, you have to disconnect the vacuum advance. Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/#findComment-254635 Share on other sites More sharing options...
July 28, 200816 yr Author comment_254658 Thanks, was researching my "How to rebuild your L Series: last ngiht and found that exact statement. So I should be looking for 5 BTDC and no more than 36 degrees at say 3500 rpm without the vacuum advance then.I will let you know, by the way I am running the Pertronix on my car. Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/#findComment-254658 Share on other sites More sharing options...
July 28, 200816 yr comment_254675 FWIW, I run 31 degrees total advance. No vacuum advance Weights have been locked. Rev engine to 4k, set timing with an electronic light at 31 degrees. Good luck. Link to comment https://www.classiczcars.com/forums/topic/28843-what-is-the-base-timing-on-a-stock-240z/#findComment-254675 Share on other sites More sharing options...
