Posted July 27, 200816 yr comment_254587 :stupid: Alright i just bought a 77 280z. I've taken off the intake and exhaust manifolds and lines running on it. nothing is attached to the engine... except the tranny. and I can't get it to seperate for the life of me i've taken all of the bolts off from the bellhousing and it seperates a bit... but i can't get them apart....... i'm probable missing a step:stupid: can you fill me in? (never pulled an engine before) Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/ Share on other sites More sharing options...
July 27, 200816 yr Author comment_254588 The engine and transmission are for sale by the way and fuel tank, in san bernardino, cali. Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254588 Share on other sites More sharing options...
July 27, 200816 yr comment_254593 Did you remove the shield on the bottom,between the engine and tranny. Did you undo the engine mounts? make sure all hoses are pulled (Heater Hose) Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254593 Share on other sites More sharing options...
July 27, 200816 yr Author comment_254594 yup the engine is comming up nicely but it wont completely seperate from the transmission... should i just give it lots of hard lovin? (beat it around?) Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254594 Share on other sites More sharing options...
July 27, 200816 yr comment_254595 I would just shake it loose and shake it good. If you want to use a rubber mallet then go ahead. I have really never had to pry one apart. Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254595 Share on other sites More sharing options...
July 27, 200816 yr comment_254596 You're probably binding ont the input shaft. You've got to place a jack under the trans and raise both engine and trans slightly so that the engine is clear of the mounts and when they're both level relative to each other and all of the bolts are out, gently pull them apart. Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254596 Share on other sites More sharing options...
July 27, 200816 yr comment_254598 did you remove the starter? Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254598 Share on other sites More sharing options...
July 27, 200816 yr Author comment_254600 yeah i removed the starter and all the bolts. the engine and transmission are seperated by about a 1/4 inch, i can see to the otherside. sweet. yeah, its probably... binding? idk i'll put a jack under it right now and try to level and pull them apart thanks Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254600 Share on other sites More sharing options...
July 28, 200816 yr Author comment_254602 SWEEEEETT!!!! It worked like a charm sblake01 Thanks a 2-TON!! :-) Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254602 Share on other sites More sharing options...
July 28, 200816 yr comment_254604 You know, I just realized that you're probably about 5 minutes or so away from me. Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254604 Share on other sites More sharing options...
July 28, 200816 yr Author comment_254627 really? san bernardino? kool. I'm actually trying to make an electric vehicle out of this datsun. that blue Z looks really nice by the way Link to comment https://www.classiczcars.com/forums/topic/28844-how-to-pull-engine/#findComment-254627 Share on other sites More sharing options...
