Posted September 3, 200222 yr comment_14714 ive been have this problem with my right front wheel. when i turn left or depress the brake pedal i get this howling noise like a bad wheel bearing.put the car up today. inspected the bearings they look well repacked and tried it again.its not as bad now. but still making the same noise. i have new bearings and seals on order from courtesy nissan, but i was wondering could it be anything else??the wheel is nice and tight i dont feel any play in it at all.anyone have a clue. thanks james Link to comment https://www.classiczcars.com/forums/topic/2887-wheel-bearings-maybe-but-what-else/ Share on other sites More sharing options...
September 3, 200222 yr comment_14726 Wheel bearings aren't tight enough, rotor warped or has excessive runout, piston hanging up in caliper, tire rub, wheel contacting ball joint, could be a lot of things. :tapemouth Guess it's a process of elimination to find the problem. Link to comment https://www.classiczcars.com/forums/topic/2887-wheel-bearings-maybe-but-what-else/#findComment-14726 Share on other sites More sharing options...
September 3, 200222 yr comment_14730 Dust shield rubbing against the rotor is another thing it could be . Link to comment https://www.classiczcars.com/forums/topic/2887-wheel-bearings-maybe-but-what-else/#findComment-14730 Share on other sites More sharing options...
