Posted August 1, 200816 yr comment_255122 Hey everyone, when I bought my car there was a light blue overspray on a large majority of the interior panels. What would you guys suggest for cleaning this off? I was thinking paint thinner or turpintine but wasn't sure if it would be to strong as to damage the door panels, seats, and other trim panels. Any information would be greatly appreciated. Thanks, Elliot. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/ Share on other sites More sharing options...
August 1, 200816 yr comment_255127 First try the LEAST aggressive solution ... soap and water. It may not remove all (or any) but then again it may.Next, follow up with either a cleaner/ conditioner for vinyl or plastic OR plain old mineral spirits (which is also known as paint thinner, just be sure it isn't LACQUER paint thinner). I've even used Denatured Alcohol.If it still persists, then with extreme care and for very short lengths of time, I would start with a rag that's very lightly moistened with lacquer thinner (to dissolve the paint). You may lift some of the panel paint / dye, but that's why you're being extremely careful.HTHE Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255127 Share on other sites More sharing options...
August 1, 200816 yr comment_255128 I have used grease and wax remover to remove overspray but the paint was never more than a week old. Brake fluid or Easyoff oven cleaner can remove paint from plastic model car bodies. I would try it on some scrap pieces first though. Follow up with soap and water afterwards. Let us know what you find that works. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255128 Share on other sites More sharing options...
August 2, 200816 yr comment_255192 You could try Goo Gone, it is a citris based cleaner that should take it off. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255192 Share on other sites More sharing options...
August 2, 200816 yr comment_255195 DougN said: You could try Goo Gone, it is a citris based cleaner that should take it off.I think the citrus is in there to smell good, make people think it's safe, and mask the fact that it works using petroleum based solvents. I recall when I was trying to remove remnants of floorboard tar mats looking at Home Depot for all the different options. I don't remember if it was Goo Gone or another similar product but the main ingredient was xylene. I decided to buy a full quart of pure xylene for less than the small can of the goo product.http://householdproducts.nlm.nih.gov/cgi-bin/household/brands?tbl=brands&id=13009002 Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255195 Share on other sites More sharing options...
August 2, 200816 yr comment_255196 My first choice for removing as you describe "light overspray" is WD40 and one of those kitchen scrubbing pads, like a scotch brite but not as abrasive. Even get one out of the kitchen your already using if you want even less abrasiveness. I get no name brand ones at the dollar store. Follow up with a soap & water solution. Like E says, try the soap & water first though. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255196 Share on other sites More sharing options...
August 2, 200816 yr comment_255203 Motsenbocker's Lift Off #4 worked well for me. On thick paint (I used it to strip my mirror housings) it takes a bit longer, but for what you are talking about it should work quite well, rather quickly. Safe and mild, though I would still suggest wearing some latex gloves (more to keep your hands clean than anything else).I found it at Lowe's, but I imagine any home repair place would have it or could order it.http://liftoffinc.com/ Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255203 Share on other sites More sharing options...
August 4, 200816 yr comment_255365 Get yourself some fast evap pre-cleaner. It's used to clean surfaces before automotive painting. It's kind of like a mild paint thinner. This has always been my favorite product to remove overspray. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255365 Share on other sites More sharing options...
August 4, 200816 yr comment_255373 In a well ventilated place, with a rebreather and a radition suit on, "Contact cement remover" works well. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-255373 Share on other sites More sharing options...
September 12, 200816 yr comment_260174 is not contact cement remover acitone? Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-260174 Share on other sites More sharing options...
September 25, 200816 yr comment_261651 grantf said: is not contact cement remover acitone?Usually it's MEK, which will disolve the dye on your panel. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-261651 Share on other sites More sharing options...
September 26, 200816 yr comment_261745 geezer said: My first choice for removing as you describe "light overspray" is WD40 and one of those kitchen scrubbing pads, like a scotch brite but not as abrasive. Even get one out of the kitchen your already using if you want even less abrasiveness. I get no name brand ones at the dollar store. Follow up with a soap & water solution. Like E says, try the soap & water first though.Yeah, what he said:smoke: WD40 is also great for removing tar from the road off of your paint job. As a matter of fact, these are about the only purposes I have found WD40 good for. As far as lubrication,,two words,,,Fluid Film,,,a bit pricey, but worth it. Link to comment https://www.classiczcars.com/forums/topic/28892-overspray-on-interior-panels/#findComment-261745 Share on other sites More sharing options...
