Posted August 9, 200816 yr comment_255910 I am putting together my gas cap with new rubber flap. Does the flap go under the flange of the fill tube or between the fill tube flange and the metal ring. FSM is not specific and the "How to" book just says to make sure you install it.Early 260ZThank you for the help,Skip Dawson Link to comment https://www.classiczcars.com/forums/topic/28969-installing-rubber-at-gas-cap/ Share on other sites More sharing options...
August 9, 200816 yr comment_255914 Assuming your 260Z is the same as my '71 240Z, the flap goes under the filler neck flange. Link to comment https://www.classiczcars.com/forums/topic/28969-installing-rubber-at-gas-cap/#findComment-255914 Share on other sites More sharing options...
August 10, 200816 yr Author comment_256036 Thank you for responding. Yes it is the same as the 240z. Link to comment https://www.classiczcars.com/forums/topic/28969-installing-rubber-at-gas-cap/#findComment-256036 Share on other sites More sharing options...
