August 11, 200816 yr Author comment_256068 luv24ds said: I have your solution.... its called nitrous oxide. In the correct dosage its perfectly safe, is easy to conceal, and will not affect your normal drivability, and can beinstalled in a weekend. Something about nitros...seems like cheating Is you're car running? What's your current engine setup? Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-256068 Share on other sites More sharing options...
August 11, 200816 yr comment_256069 mikewags said: Something about nitros...seems like cheating Is you're car running? What's your current engine setup? I'm putting my wifes 240z together. I am a musclecar guy, but plan to build a hopped up Z car for myself someday. We are running a stock 240 engine with a 5speed zx transmission. The car was pretty darn quick before and it had an automatic. My car is a 1971 buick ( ) with a 600hp 455( ) Its mean and nasty. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-256069 Share on other sites More sharing options...
August 11, 200816 yr Author comment_256070 Holy @*#$ ... big engine. Any ideas on what kind of effect would a turbo-charger do on the stock L28e? Would this risk blowing the engine since it isn't designed for the extreme air intake? If not, would the performance gain be worth it? Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-256070 Share on other sites More sharing options...
August 11, 200816 yr comment_256071 mikewags said: Holy @*#$ ... big engine. Any ideas on what kind of effect would a turbo-charger do on the stock L28e? Would this risk blowing the engine since it isn't designed for the extreme air intake? If not, would the performance gain be worth it?I am no expert on turbocharging but I am becoming a huge fan of the technology. You can safely turbocharge your engine. You may not be able to run a lot of boost, but you still should be able to increase your power considerably, even with low boost levels. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-256071 Share on other sites More sharing options...
August 11, 200816 yr Author comment_256075 I might look into this...seems like a relatively inexpensive way of making some power gains. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-256075 Share on other sites More sharing options...
November 17, 20213 yr comment_631705 Hi. Without all the 'do more research' and 'this topic has already been answered' and 'well that's a big topic so be more precise' guff that you get from forum kings here is a good list that will help you. 1. Tyres 2. Brakes 2b. Both 1+2 together would be great! 3. Suspension. 4. LSD diff 5. Get 14k and order a Rebello Engine. You're welcome. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631705 Share on other sites More sharing options...
November 17, 20213 yr Popular Post comment_631711 Don't they use the same calendar in Neuvecelle as the rest of the world? This thread is 13 years old. mikewags hasn't visited the site since 2010. Welcome to the forum. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631711 Share on other sites More sharing options...
November 17, 20213 yr comment_631720 That was a pretty epic first post Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631720 Share on other sites More sharing options...
November 18, 20213 yr Popular Post comment_631723 On 11/17/2021 at 8:40 PM, 280zxSpectrum said: guff that you get from forum kings I'm a forum princess and should be treated that way. Edited November 18, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631723 Share on other sites More sharing options...
November 18, 20213 yr comment_631726 On 11/18/2021 at 2:02 AM, siteunseen said: I'm a forum princess and should treated that way. Have to be careful about dating that "princess" siteunseen! 😉 Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631726 Share on other sites More sharing options...
November 18, 20213 yr comment_631731 Everything else is just an acquaintance. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631731 Share on other sites More sharing options...
November 18, 20213 yr comment_631736 Given that the French are a bunch of backwards ingrates it will come as a shock that they have managed to follow common era for at least 7 years if not more. Your focus on the ‘bad’ in my post only proves my point chaps but I’ll let you off because you said my post was epic. Unless it’s just you two and me on here now that mikewags has sadly left, perhaps my post can be helpful to others on a similar search for more power from their 6? Just a thought. Onwards and upwards. Link to comment https://www.classiczcars.com/forums/topic/28974-pushing-for-more-hp-on-the-l28/?&page=2#findComment-631736 Share on other sites More sharing options...
