Posted August 11, 200816 yr comment_256152 I haven't posted in some time.right now im installing my r200 diff in my 72 240z and i notiiced that i have no brackets for a sway bar nor a sway bar and one of rear pasenger control arm is flipped nd not having a sway bar as well is it normal? i wanted to know how to install a sway bar on the rear i know my o73 had a sway bar. Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/ Share on other sites More sharing options...
August 11, 200816 yr comment_256171 There are two options for the rear sway bar......the factory set-up and an aftermarket set-up. With a little bit of searching in our archives section, you should find all your answers regarding rear sway bars!Tom Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256171 Share on other sites More sharing options...
August 13, 200816 yr comment_256524 Yes, the flipped rear A arm is normal. On my car, the driver side is smooth up, and the pass. side is opposite. Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256524 Share on other sites More sharing options...
August 14, 200816 yr Author comment_256541 hmm why would nissan do that? but i changed out anyways Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256541 Share on other sites More sharing options...
August 14, 200816 yr comment_256542 It is always cheeper to make one part than two...Will Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256542 Share on other sites More sharing options...
August 14, 200816 yr comment_256573 I would guess that the rear A arms are interchangeable because the Z was a rally car. Its not only cheaper to forge 1 part instead of 2, but the interchangeable A arms means 1 less spare part to carry in the chase car also. Just my guess. Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256573 Share on other sites More sharing options...
August 14, 200816 yr comment_256579 To expand on what hls30.com said..In manufacturing there is a fixed cost with respect to tooling and fixturing. By using the same part on both sides of the car they are able to spread that fixed cost over twice as many parts. The individual parts are then cheaper. This is often referred to as economy of scale. The lower control arms are designed to function identically, within reason, regardless of the side they are mounted to. Steve Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256579 Share on other sites More sharing options...
August 16, 200816 yr Author comment_256854 well i wanna know how to put a sway bar mounts on my z it doesnt seem to have any...is there an aftermarket kit? or can i just cut off mounts from another year and weld them on? Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256854 Share on other sites More sharing options...
August 17, 200816 yr comment_256884 well i wanna know how to put a sway bar mounts on my z it doesnt seem to have any...is there an aftermarket kit? or can i just cut off mounts from another year and weld them on?Suspension Techniques makes an aftermarket kit that replaces the two vertical plates that locate the rear most bushing on the A arms with plates that have "ears" which are used to mount their sway bar. Very nice kit. Much better than the MSA kit that has you drilling the floorpan behind the seats. Link to comment https://www.classiczcars.com/forums/topic/28998-doin-stuff-to-the-z/#findComment-256884 Share on other sites More sharing options...
