October 14, 200816 yr comment_263326 929, This link has a brief description and cutaway, hope this makes things a bit more clear. http://www.secondchancegarage.com/public/535.cfm I'm thinking the small hole you see in the pump is not unlike a small hole in waterpumps, that would indicate a bad seal/ failure. I have also seen the crankcase contaminated with fuel due to a bad mech. fuel pump. Tuck\o/ Edited October 14, 200816 yr by Friar-Tuck Link to comment https://www.classiczcars.com/forums/topic/29005-z-still-wont-start/?&page=2#findComment-263326 Share on other sites More sharing options...
October 14, 200816 yr comment_263329 If the weep hole is seeping gas, I suspect that you have a bad diaphragm. On my '72, the weep hole is on the "other" side of the diaphragm from the gas. If anything comes out of there it would be oil. Check to see if your oil is smelling like gasoline and thinning out on you (indicating that you are getting gas flowing on the wrong side of the diaphragm). Link to comment https://www.classiczcars.com/forums/topic/29005-z-still-wont-start/?&page=2#findComment-263329 Share on other sites More sharing options...
October 15, 200816 yr Author comment_263358 thank you all... help is on the way from MSA... we shall soon see as i will have a new pump soon! thanks again and im sure i will have more questions when we bridge this gap Link to comment https://www.classiczcars.com/forums/topic/29005-z-still-wont-start/?&page=2#findComment-263358 Share on other sites More sharing options...
