I posted something about this about a month ago but the problem didnt go away. I have a 77 l28 fuel injected in my 240z. After cleaning up the fuel rail/injectors and also the throttle body my engine developed a idle problem. When you push on the gas the rpms go high and never come back down. The linkage and everything is ok. The only way to get the rmps to come back down is if you put it into gear or to shut off the engine and turn it back on. (but once you hit the gas again...it comes back) I found that if i move the wires around and rotate the throttle valve switch the idle changes. I havnt been able to find any vacuum leaks...So can i conclude that the throttle body is bad? All the moving parts including the butterfly are working OK. I already ordered the performance big bore throttle body. Is there any way i can test this stuff before i spend more money on a new throttle body? Thank You
https://www.classiczcars.com/forums/topic/2907-idle-problem-returns/Share on other sites
