Posted August 18, 200816 yr comment_257037 Does anyone have an exploded view of the steering assembly from wheel forward?I am trying to see the horn pad mount and the steering coupler...thanks in advance. A Google search did not produce the desired result. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/ Share on other sites More sharing options...
August 18, 200816 yr comment_257058 You may have found this already.http://carfiche.com/fiche009/s30/index.pl?6:b:4 Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257058 Share on other sites More sharing options...
August 18, 200816 yr Author comment_257064 I did see this, but it doesn't show the horn pad mount. I am missing that, wanted to see if there's a part # or what it looked like. I also happen to have a spare steering coupler. Rather than taking everything apart, I wanted to see the position in the column. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257064 Share on other sites More sharing options...
August 19, 200816 yr comment_257096 At the same place as Camo's link, go to: 6 c 4Or in the club's microfiche, Section 103-1 under Steering.HTHE Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257096 Share on other sites More sharing options...
August 19, 200816 yr Author comment_257137 Thanks - I'll look again! Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257137 Share on other sites More sharing options...
August 19, 200816 yr comment_257162 So I have another questions on from the microfiche. How can I find the part number for #33 on the diagram (lower u-joint). I have been looking for a replacement for some time. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257162 Share on other sites More sharing options...
August 19, 200816 yr Author comment_257163 Enrique - thank you again, this provides the view / parts I am looking for!! Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257163 Share on other sites More sharing options...
August 19, 200816 yr comment_257164 So I have another questions on from the microfiche. How can I find the part number for #33 on the diagram (lower u-joint). I have been looking for a replacement for some time.Part numbers are listed below, you just have to click the right link till #33 is displayed 6b6 & 6b7 depending on your cars year. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257164 Share on other sites More sharing options...
August 19, 200816 yr Author comment_257169 Mr C. - I didn't thank you either, my apologies - thanks for pointing me to this site.Now I have an even "dumber-er" question - I can't find the mounting kit / parts...at least not online. Arne once pointed out that you can get parts via a Nissan dealer, but I am not confident in my local dealer.I did see a Grant steering wheel mounting kit at JC Whitney. Obviously, it's intended to mount a Grant steering wheel - wondering if some of the parts could be sourced to mount the horn pad on an OEM wheel...anyone know?Am I making a bigger deal out of this than it needs to be? Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257169 Share on other sites More sharing options...
August 20, 200816 yr comment_257359 I think you'd have better luck with ebay, sourcing a second hand part, than trying to adapt an after market part. Maybe just try asking if any of the members here have a spare they want to part with. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257359 Share on other sites More sharing options...
August 20, 200816 yr comment_257364 Maybe this will help.... I was looking for some of these parts as well - found them on ebay rather inexpensively.... I needed replacement for #19 because it cracked and one of the #20 pieces that grips the pad/button had broken away leaving the pad to rest in your lap after each good bump. Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257364 Share on other sites More sharing options...
August 20, 200816 yr Author comment_257373 What / how did you search? Is it a horn pad mounting kit or something else? Link to comment https://www.classiczcars.com/forums/topic/29090-steering-exploded-view/#findComment-257373 Share on other sites More sharing options...
