Email logins are now active ×
Can anyone recommend someone to rebuild a 5-speed transmission
jthill3
That's hard to say, without knowing more about the internal condition. I spent over $300 on parts alone when I rebuilt my Type A four speed. I bought the bearings from a generic bearing supplier who was significantly cheaper than Nissan, but I did buy Nissan synchro rings, even though aftermarket would have been a lot less. A five speed needs one more synchro ring than mine, otherwise the parts list should be similar. So call it $350-400 in parts.
If you are just dropping off the 'box itself, a good rebuilder could probably do the job in a day if he had all the necessary shims and different thickness snap rings on the shelf. Maybe a day and a half at most. Let's say 8-12 hours. What's his rate? Probably $50 per at least. so a minimum of $400 in labor, maybe $600.
So if you are going to pay someone to do it for you, figure $800-1000 at least. More if there are any worn or bad parts beyond the bearings and synchros. Gears and shafts will add a lot to the price.
Edited by Arne
