I'm running 205/60-15 Kumho's on Swastika rims and I get a small rub if I'm backing up and turning to either side. If I'm careful and don't turn too much, then I have no rubbing at all. My car currently has the stock ride height, and the tire is rubbing at the back of the valence. I plan to eventually change to 16x7's, lower profile tires, and lower the car, so I don't expect future rubbing.
My input anyway.
Greg
  • 2 years later...
Nexan's 5000 are nice as well as all Falkens I have tried.
Quiet, sticky, good in water. The falkens wear faster.
I have Yokohamas on my S2000. Scary in rain and Rear's have worn in the middle. I dropped pressure from 32psi to 28psi and still centre wear.
What kind of Yokohamas do you have? I just bought 205/60/R15 Yokohama Avid Envigors (haven't put them on yet). Hopefully I have better luck.
