Air Compressor Regulator - Can it be Fixed?
DeesZ
If you have any experience with compressor regulators I'm seeking your advice. Mine is going south on me slowly but surely - it is starting to stick open, not allowing me to regulate the pressure down once I have it at a higher output (without a bit of fritzing around with it a bit). My question is "Can it be fixed or should I simply replace it?" I've attached a picture so you will have an idea what I'm talking about. (I didn't buy it new and assume it's a Harbor Freight quality unit.)
If it can be fixed, any advice on doing so?
If replacement is in order, any advice on an economical unit?
(The compressor builds up a head of about 175 lbs.)
Your suggestions and or advice will be greatly appreciated.
Thanks!!
Picture attached:
  • Who's Online   3 Members, 0 Anonymous, 590 Guests (See full list)
