Email logins are now active ×
Intermittent Complete Power Loss
ONZEDGE
Hello. I drive a 71 daily driver and it is very reliable until yesterday. Driveing down the fwy at about 3400 rpm the engine stopped for a split second. The remainder of the drive was uneventful. This morning howebver it happened again 4 or 5 times during a 20 mile drive to the office.
Coming home it became more frequent and it actually stalled while driving down my street in 1st gear. Following this stall was a loud backfire.
When it happens it is like someone kills the ignition -- just for a second.
It is freshly tuned and I have a new ignition switch. I run a mallory dual point with an MSD coil. All of the connections look good.
Please help with this puzzler.
ONZEDGE
Here is another thing for you to check- I once had the brass connector fail on the wire that goes to the distributor. It cracked and broke inside the clear outer protector, maybe yellow now from age, so if you looked at it you would swear the wire was connected. It would arc back and forth and make intermittent contact. Since it controls the ignition circuit going to the points it was like you turned off the key. If that connector is okay then be certain to check them all. Good luck
