Does anyone have some pics of the 1972 console? Specifically, the embossed piece just after the stick shift and the accessory panel (w/ defroster).
I just looked at a 1972 parts car - it had some bits I wanted to poach. I noticed that the accessory panel was different than mine, so I am curious which would be the right piece. The parts car had a "fasten seat belts" warning light in the center, where I have a rocker switch with a red lens. I am pretty sure the "fasten seat belts" is correct, but since there were tweaks made from '70-'73, I am not certain.
For the embossed piece aft of the stick, I have an aftermarket air conditioner control unit. Since that required cutting away the console piece, I may try to acquire the entire console from the seller.
https://www.classiczcars.com/forums/topic/29225-1972-console/
Mike - thanks for posting. I thought as much. I wonder what the rocker switch is in my car, but obviously it's not right. I'll see if I can pinch this piece (and defroster switch).
Thanks!
  • 1 month later...
