brush gaurd help
the_cafe
me and the buds are goiin huntin which means i have to take the zed down
some brush coverred trails. i need to know iff anybodyz welded some tipe of brush bar to the front of there zed becaus i need to put one on mine so it doesnt get brush sucked into the fan. doesnt have to bee pretty
what kind of medal do u think i should use/
i need somthin that will hold up and not bent if i hit something lightly. what paint do i use to? i think weld or bolt the top to the hood and weld the bottom to the underside
the bumber
the bumber
I think welding it to the hood and underside would be the best way to do it. Z's are famous for their reliability so you shouldn't need to open the hood for a really long time. Believe it or not but the Z hood is one of the strongest hoods ever made and should be quite capable of handling any load you might put on it. As far as paint goes a good exterior latex house paint because the outside of your house is always outside so that paint is really good for outside stuff. Home Depot has lots of it and can mix any color you'd like.
Or maybe not.
Steve
Well, you could start with something like this, but why stop there?
Maybe you should find yourself an old datsun 4x4 truck, yank out all the guts from it and throw them in/on your Z? Slap on some mud tires and off you go!
Or better than that, just get yourself an old datsun 4x4 truck and use it...
If it were me I would take the bumper off and bolt on a brush guard from a police car or even on from a ford ranger. Then go and get some paint from Wally world and paint the hell out of it. Make sure you get the special cold weather paint cause its fix-in to get real cold there in minnesota. You might want to look into a winch for the brush guard just in case you have to pull a big'n up a hill or something.
