In an attempt to replace my steering rack and bushings I came across this problem.
I purchased a rack from a guy thinking it was a '73. (box labled '73) Thought it would be fine looks pretty much the same only a little heavier perhaps. Everything bolts up fine, but the bushings (new MSA urethane) Are 1/4 of an inch narrower than the seats for them in the rack. My question is: are the bushings too norrow or could this be a rack from a '74 260.
Also found a tiny bit of play between the steering coupler donut and the steering wheel itself. What the heck is that? The splines in the steering wheel itself?
Any input greatly appreciated. Was hoping to race around on the mountain a bit.
Thanks,
H Houghton
It was the bushings for sure, new ones came in yesterday and are 1/4 wider and a good bit heavier. Will get them in on Monday or Tuesday.
There is a small amount of play in the column. By holding the the do-nut coupler and reaching through the window and moving the wheel I have isolated the slop btween these two points. I assume that it is in the interface between the solid shaft and the collapsible bit in the middle?
Let me know about your part.
Best,
H Houghton
