Email logins are now active ×
Stock Mustache Bar Bushing Replacement??
Dr_rich
Ok. I have a '73 240Z.
I installed urethane bushings in my mustache bar after burning and tapping out (Thanks Beandip for helping!).
I quickly realized after driving that I hear all my transmission gears Very clearly now, which is not what I wanted.
I got the new OEM bushings and two of the Large OEM rubber-covered washers.
So tonight, I pulled the mustache bar out, and took out the urethane bushings to reinstall the new OEM bushings.
But do I have to cut out the sleeve inside each end of the mustache bar to install the OEM bushings?
And if so, what is the best way to cut out the old sleeves?
I have some pics of this if would help.
Any help would be much appreciated!
Thanks!!
~Richard
