Posted September 3, 200816 yr comment_259073 I saw an eBay listing for a "solid" billet (metal) front differential mount. It would certainly eliminate movement, but I'm thinking it could be pretty harsh and might require precise alignment of the driveshaft. My guess is it might be OK for a dedicated track car, but not that great on the street.Just installed a new "stock" rubber front mount on mine. Not considering a switch, just curious what others think... Link to comment https://www.classiczcars.com/forums/topic/29268-solid-front-differential-mount/ Share on other sites More sharing options...
September 3, 200816 yr comment_259108 I'd stick with the stock mount for the street. The mustache bar is rubber mounted too so having one solid mount and one flexible mount isn't the greatest idea. Something will eventually crack. Steve Link to comment https://www.classiczcars.com/forums/topic/29268-solid-front-differential-mount/#findComment-259108 Share on other sites More sharing options...
September 3, 200816 yr comment_259132 I saw an eBay listing for a "solid" billet (metal) front differential mount. It would certainly eliminate movement, but I'm thinking it could be pretty harsh and might require precise alignment of the driveshaft. My guess is it might be OK for a dedicated track car, but not that great on the street.Just installed a new "stock" rubber front mount on mine. Not considering a switch, just curious what others think...I installed a solid mount on my diff about 5 years ago. I don't think it is too harsh for the street or harsh at all for that matter. Link to comment https://www.classiczcars.com/forums/topic/29268-solid-front-differential-mount/#findComment-259132 Share on other sites More sharing options...
September 3, 200816 yr comment_259146 I installed a solid mount on my diff about 5 years ago. I don't think it is too harsh for the street or harsh at all for that matter.When was the last time you checked your diff crossmember for cracks?http://forums.hybridz.org/showthread.php?t=125046 Link to comment https://www.classiczcars.com/forums/topic/29268-solid-front-differential-mount/#findComment-259146 Share on other sites More sharing options...
September 3, 200816 yr comment_259159 Jmort is right. Mine had cracks too. I ran mine and endured the deafening whine from gear noise for several years. There have been posts on HybridZ bemoaning the solid mount. My solid mount now sits on a shelf as a temporary backup. Seemed like a good idea when I bought it. Ron Tyler style mount is great!... Near bullet proof. Carl Beck just posted another simpler style mount which is a nice design too. http://www.classiczcars.com/forums/showthread.php?threadid=31777 (16th post) Link to comment https://www.classiczcars.com/forums/topic/29268-solid-front-differential-mount/#findComment-259159 Share on other sites More sharing options...
