I am in need of a gas tank for a 1970 240z. I need to know if anyone has the dimensions on the gas tank or if they know if there is a tank you can use in replacement of the original.. Thanks in advance of any help...
https://www.classiczcars.com/forums/topic/29275-gas-tank/
If worst comes to worst, I have a gas tank out of an early 74 that should match up. I'll crawl under it tonight, see if I can get some decent measurements of it. It does go under the spare tire area, so it is rather Asymmetrical.
https://www.classiczcars.com/forums/topic/29275-gas-tank/#findComment-259188
