Power to coil
1rad280
My 1976 280z balast resistor has a black and white wire that is hot when the key ON. A black and blue wire has power only when cranking the engine and another black and white wire that goes to a capasitor. When I crank the engine no spark from the coil but when the key is on ACC the coil wire sparks. I have a mallory coil, mallory distributor. Any Ideas?
Sound like something is wired wrong. You shouldn't have power to the ignition coil when the key is in the ACC position.
From a 1978 280Z wiring diagram:
The black w/white stripe powers the ignition relay.
Blue w/white stripe goes to the ballast resistor.
Blue wire goes from the ballast resistor to the ignition coil.
Was it running previously? Since you have an aftermarket coil and distributor I hope the installer wired it correctly.
Edited by Curtis240Z
