Posted September 8, 200816 yr comment_259676 hello, I just got a 280z for three hundred bucks, not runningsome rust through on the rear quarter panels, rockers and front fenders (no rust on the floor and rusty hatch. wiring is an absolute mess, brake lines need flushing and maybe a master cylinder rebuild.anyhow the previous owner said there was a short to the fuel pump, located the fuel pump test the wires and they were fine, pulled the pump tested it and it was dead. installed new fuel pump and bingo! started right up!sounded pretty good for not running for over a year. Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/ Share on other sites More sharing options...
September 8, 200816 yr comment_259677 Way to go! Keep chipping away at the issues and before you know it, you'll have good looking, good running Z. Advice is FREE here, so don't be shy about asking if you run into any problems.Dennis Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259677 Share on other sites More sharing options...
September 8, 200816 yr Author comment_259679 thanx here is a pic the seller took before i got it. Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259679 Share on other sites More sharing options...
September 8, 200816 yr comment_259680 Great deal for buyers like you that find the real problem! Go luck with the rest of it and have fun! Don't let the rust get out of hand. Edited September 8, 200816 yr by Curtis240Z Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259680 Share on other sites More sharing options...
September 8, 200816 yr Author comment_259681 oh and did I mention it is a five speed.so my first question.......(I hate to ask this)what is the best engine oil to use? Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259681 Share on other sites More sharing options...
September 8, 200816 yr comment_259684 so my first question.......(I hate to ask this)what is the best engine oil to use?Ask 10 guys and you will get 10 different answers. These older engines were designed when the lightest oil weight was 10W, so I use 10W-30 Mobil 1 because it is synthenic which is generally superior to conventional oil. Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259684 Share on other sites More sharing options...
September 8, 200816 yr comment_259691 Welcome. Is your car a 78? Is black it's original color? You may have done even better that you think on your purchase. If it's originally black it's a Black Pearl Edition. If the paint code tag is still there on the radiator support, see if it had '638' for the paint code. Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259691 Share on other sites More sharing options...
September 8, 200816 yr Author comment_259744 yes it is a 78the red pinstripping is a little faded.....just kidding it's original color was yellow.(but it is a 78) Edited September 8, 200816 yr by grantf Link to comment https://www.classiczcars.com/forums/topic/29319-first-post/#findComment-259744 Share on other sites More sharing options...
