Posted September 10, 200816 yr comment_259979 Ok, need your opinion on emblem location on a BRE style rear spoiler.. 1) Should I install emblems on the spoiler?. 2) Install just the "240Z" emblem, "Datsun" Emblem, or both?. 3) Where to locate emblem(s)?Figured it's all been tried before, so why re-invent the wheel... Post pics if you have them.Thanks! Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/ Share on other sites More sharing options...
September 10, 200816 yr comment_259980 I'm not putting the emblems on my rear spoiler, if I were going to, I would build up a flat on the spoiler like that on the 432, and put'er there, just like on Kats car. Will Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259980 Share on other sites More sharing options...
September 10, 200816 yr comment_259981 This is what would be considered "correct" to give you an idea. Of course, you wouldn't use the Z432 or Fairlady emblem. However the BRE spoiler you are refering to is actually a reproduction of the Nissan spoiler as shown. I suggest you use the Datsun emblem and the 240Z emblem from the rear deck as the spoiler covers them up. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259981 Share on other sites More sharing options...
September 10, 200816 yr comment_259983 Things were probably different by 78 but my Z came with a dealer installed rear spoiler and the emblems were removed. I put the 'Datsun' and '280Z' emblems back on the deck just above the spoiler. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259983 Share on other sites More sharing options...
September 10, 200816 yr comment_259984 Does your spoiler have the flat spot on it? Most reproductions I have seen do not have the flat spot. I believe Chris has the answer I agree with. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259984 Share on other sites More sharing options...
September 10, 200816 yr comment_259988 Oiluj said: Ok, need your opinion on emblem location on a BRE style rear spoiler.. 1) Should I install emblems on the spoiler?. 2) Install just the "240Z" emblem, "Datsun" Emblem, or both?. 3) Where to locate emblem(s)?Figured it's all been tried before, so why re-invent the wheel... Post pics if you have them.Thanks!I have a BRE style rear spoiler that does not have the raised flat spot, so I have decided to forego any emblems on the hatch lid or spoiler. No such thing as correct in this case because the spoiler is aftermarket anyhow. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259988 Share on other sites More sharing options...
September 10, 200816 yr Author comment_259994 Not so worried about being "correct", just what looks good...I'm leaning towards just putting on the "240Z" emblem on the right side. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259994 Share on other sites More sharing options...
September 10, 200816 yr comment_259996 Hi Take a look at my rear deck car. I really enjoy it. The way it shows was the way that all standard 240z were delivery in Portugal. Besides that the rear spoiler (Original Nissan Part) has the holes for the corect possition od the "Datsun" and "240z" emblems. FilipeA Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259996 Share on other sites More sharing options...
September 10, 200816 yr comment_259998 I elected to go without. Of course, the only emblems on my car are on the rear roof vents and on the hood...... Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259998 Share on other sites More sharing options...
September 10, 200816 yr comment_259999 Hi Julio:There are actually three different rear spoilers being discussed here. So the first question is, "which one do you have?"1. An original Nissan OEM rear spoiler2. The aftermarket reproduction of the OEM rear spoiler {produced most recently by Classic Datsun Autosports - Les Cannaday}.3. The BRE style rear spoiler - also reproduced most recently by CDM/LesThe first two will have the raised flat area - intended to hold the emblems, the third type will not have the raised flat area. If you have the #3 type, I'd leave the emblems off, as it is hard to mount a flat emblem on a curved surface.In any case, if you remove the emblems from your deck lid, make sure you fill the holes before mounting the rear spoiler. 100% silicone calking or RTV will seal the holes without damage to the body.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-259999 Share on other sites More sharing options...
September 11, 200816 yr Author comment_260021 Thanks for the input and pics everyone!Since I planned to install a spoiler, I had the emblem holes in the rear deck welded over when it was in paint prep to eliminate potential leakage issues.My spoiler is the BRE style with the curved face rear face, (no flats). I'm not worried about attachment, as I've got some 3M foam emblem tape. If I recall, it's about 0.015" thick. I've stacked layers to mount emblems on curved surfaces and it's worked well for years without any problem. I learned the trick is to clean all surfaces "exceptionally" well, then install on a warm, dry surface and wait 24 hours to allow the adhesive to "set".I still not certain what I'm going to do. Guess I'll wait until I have the car back on it's wheels. Then we and can look at it out in the sun with emblems installed with masking tape in various locations. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-260021 Share on other sites More sharing options...
September 11, 200816 yr comment_260026 I can't believe I'm going to say this, as I have a pet peeve about 240Zs with no emblems. But on that BRE spoiler with no flat mounting surface, I'd leave them off. Link to comment https://www.classiczcars.com/forums/topic/29340-emblem-location-on-rear-bre-spoiler-_-poll/#findComment-260026 Share on other sites More sharing options...
