My '73 (just got the newly rebuilt L28 running in her) has a weird signal quirk. Right works fine, but left stays solid when at idle. When I give it a little gas, it blinks normally, just like the right one. Strange.
"Go into emptiness, strike voids, bypass his defences; hit him where he does not expect you" -Lao Tzu
https://www.classiczcars.com/forums/topic/294-signal-speed/
Sounds like you have a problem with voltage to the left,try checking the indicator output voltage from the switch.and comparing it with the right hand side,probably a poor contact/connection.My 73 240 has been suffering from corroded connections from the age of the wiring.
Hope this helps.
https://www.classiczcars.com/forums/topic/294-signal-speed/#findComment-617
