Posted September 19, 200816 yr comment_260947 Hello All,I got to working on th 74.5 260 2+2 I got a few months ago. I decided I needed to replace the springs and struts. So I bought he poly bushing set from black dragon and went to town. To my horror several of the bolts holding on things like the transvers link and even one of the half shafts were only finger tight. GOOD THING I Broke it down when I did and stopped driving it! My questions is this. Is her any reason I shouldn't use the locktite on all of the stationary bolts when remounting them? I am actually hopping to be done today or tomorrow. Thanks,Nick Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/ Share on other sites More sharing options...
September 19, 200816 yr comment_260949 You can use loctite on suspension bolts, sure. The transverse link and halfshafts should have lockwashers on them though. There are torque specs for the suspension bolts too. Might be a good idea to go around and check everything. Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/#findComment-260949 Share on other sites More sharing options...
September 19, 200816 yr Author comment_260952 Thanks Jon,Do you or does anyone know where I might find the torques specs? Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/#findComment-260952 Share on other sites More sharing options...
September 19, 200816 yr Author comment_260955 Nevermind on the torque specs they are in one of my repair manuals. If anyone needs them shoot me an email and I would eb happy to post them. Edited September 19, 200816 yr by nhoddino Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/#findComment-260955 Share on other sites More sharing options...
September 20, 200816 yr comment_260993 I use never seize and lock washers and a torque wrench. Rarely any loctite. Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/#findComment-260993 Share on other sites More sharing options...
September 20, 200816 yr Author comment_260996 too late. I used locktite on most all of them. I was shcocked when I found that some of my bolts were out halfway and worn almost in half. Also on my halfshaft bolts a few came of with only my one finger turnong them. It was a good thing I got under it when I did... I would hate to think of the damage had the bracket holding the transverse link had finished couming the rest of the way out, or the halfshafts had fallen off on the road. Link to comment https://www.classiczcars.com/forums/topic/29415-is-locktite-good-on-suspesion-nuts-and-bolts/#findComment-260996 Share on other sites More sharing options...
