Posted September 7, 200222 yr comment_15092 I am in the process of adding tripple delorhtos to my 70 Z.For anyone that has the same set up, do you find it necessary to upgrade the fuel pump. MSA is toting their "premim electric fuel pump". Is this necessary or does it even help?Any comments would be appreciated.Mark Link to comment https://www.classiczcars.com/forums/topic/2943-fuel-pump/ Share on other sites More sharing options...
September 7, 200222 yr comment_15104 I am running the Weber setup. It runs fine on the stock pump. I did add a Carter electric pump, but do not run it because I don't like the noise. I had a similar setup on another Z many tears ago, and it also ran fine on the stock pump.. Link to comment https://www.classiczcars.com/forums/topic/2943-fuel-pump/#findComment-15104 Share on other sites More sharing options...
September 8, 200222 yr Author comment_15170 Thanks for the feedback Link to comment https://www.classiczcars.com/forums/topic/2943-fuel-pump/#findComment-15170 Share on other sites More sharing options...
