mmagnus Posted September 7, 2002 Share #1 Posted September 7, 2002 I am in the process of adding tripple delorhtos to my 70 Z.For anyone that has the same set up, do you find it necessary to upgrade the fuel pump. MSA is toting their "premim electric fuel pump". Is this necessary or does it even help?Any comments would be appreciated.Mark Link to comment Share on other sites More sharing options...
smg1404 Posted September 7, 2002 Share #2 Posted September 7, 2002 I am running the Weber setup. It runs fine on the stock pump. I did add a Carter electric pump, but do not run it because I don't like the noise. I had a similar setup on another Z many tears ago, and it also ran fine on the stock pump.. Link to comment Share on other sites More sharing options...
mmagnus Posted September 8, 2002 Author Share #3 Posted September 8, 2002 Thanks for the feedback Link to comment Share on other sites More sharing options...
