u-joints
grantf
can i replace the u-joints on my 78 280z.
the manuals say no, but I just replaced one on one of the half shafts with no problem at all. thing is there is another bad one on the drive shaft (propeller shaft). do I need to replace the whole thing???
P.S. I have a 5 speed.
Edited by grantf
thanks for the info, but just to make sure, will a 240 or 260 shaft fit a 78 5 speed tranny. I did call around and there is a place in georgetown (Seattle) called drive-line northwest, they said they specialize in non serviceable shafts for BMW, Mercedes, and all other imports, they said they might be able to service it (cost $30 (u-joint)+ $15.50(service) & balancing. I know of two people who have used them and say they do good work. Any thoughts?
1.) Yes, the '72-74 240/260Z driveshaft is fine with a 5 speed.
2.) If the driveline shop says they can do it, they're probably right. Worth taking it in and having them look at it in person, definitely.
3.) Yes, this site does RULE!
I didn't mention that option since I thought it would be more costly than just buying a used 72-74 S30 driveshaft. I actually had Inland Empire Driveline build me a driveshaft for my 78 about 10 yrs ago. It has serviceable u joints but is a bit on the costly side compared to a stock driveshaft.
  • Who's Online   2 Members, 0 Anonymous, 757 Guests (See full list)
