Aftermarket Oil guage ?'s
Seanh
Hey, I am wanting to get a tripple gauge aftermarket set for my 72. I am wondering though, For my oil pressure gauge, I will need to remove my oil press. sending unit near my oil filter, and screw in the new probe for the gauge. But, doesn't this car have a fail safe that will shut off the engine if theres no oil press.? If so, what will I need to do to get around that?
Also, what size is the oil pressure and coolant temp sender threads/fittings? Thanks
Alright, I was just curious since I'd heard of other cars haveing them. No, my stock gauges are fine...Just that my water temp gauge only has like the 120 250 marked on it..I just want something more accurate and easier to read, Same with oil press. Thanks
Still Curious on the thead sizes for those if anyone knows off hand.
Alright, hopefully this should work without trouble then. I will be installing tomarrow probally. Yea, I am getting mechanical gauges. Just can't really find any descent place to put the 3 gauge pod, so for now its going on top of the dash in the corner until I get the time to make a spot for them in the dash. Thanks!
Holy Crap, what is with the stock temp sensor? I pulled the wire off, then unscrewed the fitting, thinking that it was a normal sensor and was all one peice, but soon discovered that its not. So I took the theaded thingy out, and tried to get the sensor out, but it just dont move...Any advice on how to get it out? Thanks
Hope you like the brakes...I would love to try mine, but the damned stupid Ford parts dept. hasn't gotten my lines in yet, so its still drive-way bound until Monday probally.
  • Who's Online   1 Member, 0 Anonymous, 613 Guests (See full list)
