If you're going to replace the metal lines, I'd replace the whole thing. Make it one-piece like the factory did, less chance for leaks. You can take the old ones out to use as a pattern for the new ones. A simple tubing bender will make the curves and you'll need to to put the hose "bulge" on the ends, if they don't come with them.
  • 1 month later...
