I bought the 2.5" exhaust system from MSA. The muffler that came with it is huge and is exposed below the body. I would like to replace it with a muffler that is smaller and doesn't hang below the body. What are your suggestions? 1971 240Z, engine is stock except for MSA header. Thanks, Darrell 240Z
https://www.classiczcars.com/forums/topic/29506-msa-muffler/
You might consider Borla muffler no. 40659. I have the 2.25" diameter model on my car. The body dimensions are identical for the 2.5" diameter model. As shown in the attached photos, it does not hang very far below the fender. This muffler might be a little longer than the MSA muffler but the "S" pipe can probably be trimmed as needed.
I suggest doing a web search for the best price. Summit Racing had all the parts I needed in stock and would price match.
Good luck.
Fixitman
Borla-Muffler40658.pdf
DatsunZ-BorlaMuffler.pdf
The other Borla muffler to consider is 40653. This is the Borla muffler that MSA offers. I had purchased the 2.25" version of this one. Though it fit, the shop found it a little tight and it extended down farther below the fender.
If you are interested in this one, I have a new, earlier Borla, but practically identical, version of this muffler with polished tip and stainless steel saddle clamps for sale at a very reasonable price. When I started my project in the 80's, I was going to use a 2.5" system again but decided to downsize to 2.25".
Fixitman
Borla-Muffler40652.pdf
Hmmm. I was able to turn the Dynomax muffler that came with my 2.5" MSA system up and tuck it in close to the body (w/o touching). My car is a '72 with an MSA 6-1 header. I would assume that the mufflers are the same, but that could be an erroneous assumption. I'll include a picture of mine for reference in case you wanted to try my approach.
Interestingly, I've seen this conflict before. I know that there are lots of people who have complained about the MSA oval muffler hanging very low. But I also have heard of (and seen) numerous cars where the muffler was able to be tucked up neatly as pictured above. I don't know what the difference is...
You guys are right on the install of the muffler. I've also got the MSA exhaust system on my 1970 and it's a simple matter of correct muffler positioning. If installed incorrectly, the muffler will hang down....when install correctly, the muffler is tucked upward and doesn't hang down.
Tom
  ktm said:
They are probably installing it wrong. If I remember, it is center in, offset out.
I figured as much, but couldn't figure out why so many people would all install it wrong. But now I see. If 'center in, offset out' is the way it fits properly, then when it fits correctly the muffler itself is technically backwards. Because the Dynomax documentation shows that the inlet is supposed to be the offset.
It seems to work just fine installed backwards. :)
MSA should probably get some better documentation though. I remember when I installed mine and I had to trial fit it several different times to see which way would be best. It doesn't hang down overly much.
Greg
