fuel pressure
madsoul
I have a 73 240 with flat tops. My runs like it is starved fuel. It feels like I am running out of gas if I maintain a high rpm. So, I dropped in some fuel dryier and replaced my fuel filters, then I replaced all my vacume lines and just recently checked my fuel pressure, cause I figured that the pumps couldn't keep the float bowls full and to my suprise the pressure ranged from 4.4 to 4.6psi. At idle and under load. I was wondering at what point too much fuel pressure becomes a problem? I was also wondering if anybody knew what the spec on the fuel volume was?
Thank you for your time,
madsoul
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
