i did find the screws and what not that I was missing along with the optical trigger. I was slowed down for a week or two between work and the fact that I moved my wife's fathers house into my garage while he was moving south. I have my space back again now and am trying to get this going for real again.
I am getting back at it now and am trying to figure out how to remove what I am assuming was the stock shutter. I tried pulling it off and what not to no avail. I don't want to damage anything so I held back. Is there some trick to it? I can take a picture of it tonight if needed but I didn't know if it was keyed somehow or anything like that.
Thanks
SuDZ
Okay, I have a few pictures I took this morning before coming into work. I was looking to see if anyone can tell me how to remove the old shutter. At least, I think it is the old shutter.
Any help would be great. Thanks so much.
SuDZ
Does anyone have any tips for this? I was looking at it again and still can't figure out how it comes off. I tried searching around on here as well but to no avail.
Thanks
SuDZ
I would presume that you need a pulling tool (jaw puller, see image) to remove the trigger ring.
Good idea. I have a pair of pullers I can give it a try with. I was just worried about damaging the metal "pole" in the middle. I will see if it gets it off for me tonight.
SuDZ
Alright, I used a pair of pullers and got the shutter off. It was stuck on their pretty good. I started wiring everything now from the optical sensor to the XR3000. Now I am running it back to the coil and need to buy a replacement clip for that. I will check out a few places today and see what I can find. After that the Ballast resistor is what I will have to figure out.
Thanks a lot. I will keep you posted.
SuDZ
Follow the instruction from Crane and Bypass the ballast resistor. If you haven't already, get a Fireball Coil or MSD Blaster 2 Coil. The OEM coil is set-up for use with a ballast resistor.
I have a xr3000 and a ps91 that was given to me and I am going to install it this weekend. Can anyone give me some info on hooking my tach up with the ps91. I have heard that it will fry my tach if hooked up directly because it runs on much higher voltage than the stock coil. Oh BTW, I have a 73 with the old points dizzy. The coil of course uses a ballast resistor. I do have a tach from a 77 but don't want to use it if I don't have to.
Edited by CrossroadsZ
wrong info
The XR3000 is a transistorized inductive ignition, there should be no problem with the voltage, which is still +12 volt to the primary coil (CDI capacitive ignitions such as the MSD 6A or Crane Hi-6 send ~500 volts to the primary coil, that would be a problem).
The '73 tach is current triggered, check out page 16 of the Crane XR3000 installation guide, which documents a similar setup based on a Smith current triggered tach.
http://www.cranecams.com/pdf/90002000a.pdf
This is not really answering your question, but at least a first step ;)
  • 5 months later...
I know it has been a while but I got off track again. I did wire up the Z so that I have spark again. I am now on to the next part of getting this all up and running.
Thanks again.
SuDZ
