November 17, 200816 yr comment_266568 I doubt if the exhaust leak is heating up the fuel rail since the rail is fairly far from the exhaust. Have you adjusted the idle screw atop the throttle body? Do you have any vacuum leaks? Have you checked the condition and adjustment of the throttle valve switch? Link to comment https://www.classiczcars.com/forums/topic/29622-78-280z-barely-running/?&page=2#findComment-266568 Share on other sites More sharing options...
