Posted October 13, 200816 yr comment_263149 HI,Does anyone have a copy or link for a BSR parts catalogue.Thanks in advance for your help!Joce Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/ Share on other sites More sharing options...
October 13, 200816 yr comment_263157 I have a few copies, but they are out of business. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263157 Share on other sites More sharing options...
October 13, 200816 yr Author comment_263159 Great!Do you have a scanned copy you could send me. I just got a part car and it have a bunch of BSR parts install and I have 4 page of parts number that was ordered.I would like to see if everything match.My email is jcote75@hotmail.com Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263159 Share on other sites More sharing options...
October 13, 200816 yr comment_263161 jcote75 said: Great!Do you have a scanned copy you could send me. I just got a part car and it have a bunch of BSR parts install and I have 4 page of parts number that was ordered. I would like to see if everything match. My email is jcote75@hotmail.com In case Curtis240Z doesn't have a scanner, and a few hours to spend scanning pages - - -Scanned copies usually run about $45.00 to $95.00 on E-Bay, depending on what years they were published. But then, if you list them on E-Bay... usually someone will let you know what the BSR Part numbers are... FWIW, Carl B. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263161 Share on other sites More sharing options...
October 13, 200816 yr Author comment_263180 Don't scanned it page by page if not already done.I'm thinking of using some of theses parts on my running 240z.Was BSR a distributor or had BSR parts?I got some invoice from BSR but would like a bref description and spec if possible.Here are the main parts:Engine: Cam: 99996-E1029Oil cooler: 21300-E4100Distributor: 22100-E3101Complete exhaust system: 50-1376Drive Train:5 Speed transmission(close ratio): 32010-N32004.11 DIfferentiel with limited slip: 38300-N3615Suspension:Front spring: 54010-E4621Strut: 54302-E4624Rear spring 55020-E4621Rear strut: 55302-E4621Brake:Front Caliper: 99996-E7005Rear Galiper: 99996-E7105Rotor: 99996-E7121These we're install in the eightees.Thanks in advance for helping sorting this out.Joce Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263180 Share on other sites More sharing options...
October 13, 200816 yr comment_263183 Nissan competition parts catalogue has some of those part numbers.Here are the ones I could find:Engine:Cam: 99996-E1029 : CAMSHAFT BILLET/UNDRILLEDDistributor: 22100-E3101 : 240Z European Distributor Hitachi D606-52 single point distributor. Quicker advance cure than the standard unit.Suspension:Front spring: 54010-E4621 : Spring/F 218 Lbs/InRear spring 55020-E4621 : Spring/R 271 Lbs/InBrake:Front Caliper: 99996-E7005Rear Galiper: 99996-E7105Rotor: 99996-E7121Front Brakes are from the Z GT2- 4 wheel Disc Brake System. Description:This 4 wheel Hurst/Airheart disc brake system is legal in SCCA GT2 option. Separate adjustable brake master cylinders for front and rear are recommended. A method of adjusting the front to rear brake bias should be adapted for proper operation of this system. Calipers do not include brake pads. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263183 Share on other sites More sharing options...
October 13, 200816 yr comment_263184 Bob Sharp was a Datsun Dealer - and many of the parts you have listed are Nissan Part Numbers. Usually the 99996 prefix indicates aftermarket parts that the Datsun/Nissan Competition Parts Department supplied through their local dealers, to customers.I think you need to see the Datsun/Nissan Competition Parts Catalogs. As I recall, BSR special parts had parts numbers that began with BSR-FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263184 Share on other sites More sharing options...
October 14, 200816 yr comment_263250 jcote75 said: Don't scanned it page by page if not already done.I'm thinking of using some of theses parts on my running 240z.Was BSR a distributor or had BSR parts?I got some invoice from BSR but would like a bref description and spec if possible.Here are the main parts:Engine: Cam: 99996-E1029Oil cooler: 21300-E4100Distributor: 22100-E3101Complete exhaust system: 50-1376 Twin Pipe Exhaust 1970-76 w/o smog (Clifford header with dual pipes and glass packs all the way back)Drive Train:5 Speed transmission(close ratio): 32010-N32004.11 DIfferentiel with limited slip: 38300-N3615Suspension:Front spring: 54010-E4621Strut: 54302-E4624Rear spring 55020-E4621Rear strut: 55302-E4621Brake:Front Caliper: 99996-E7005Rear Galiper: 99996-E7105Rotor: 99996-E7121These we're install in the eightees.Thanks in advance for helping sorting this out.JoceEach Bob Sharp catalog has a different numbering system! Some only have descriptions (it was simplier back in the '70s). Out of the five BS catalogs I have the above information is the only other item that wasn't already found for you. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263250 Share on other sites More sharing options...
October 14, 200816 yr Author comment_263302 Thanks everyone for the info.For the cam, are there any specification mention?How about the transmission and diff, are those zx parts? Those we're paid 800$ each at that time. Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263302 Share on other sites More sharing options...
October 14, 200816 yr comment_263312 Nope thats all it says with regard to the cam. Maybe it's a blank that they could grind to there own specs?? Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263312 Share on other sites More sharing options...
October 14, 200816 yr comment_263320 jcote75 said: Thanks everyone for the info.For the cam, are there any specification mention? How about the transmission and diff, are those zx parts? Those we're paid 800$ each at that time. This info is from the 'Datsun Competition Parts' catalog. I can't find a date on it but 1978 seems to be the newest year vehicle shown in it. No mention of the ZX but it does have the A10. According to the catalog 99996-E1029 is listed as an 'unground cam billet'. Also, your number for the strut, is it 54302-E4624 or 54302-E4621? If it's E4621, then everyone of those parts you listed are in the catalog I have. Here's the scans on the trans and diff: This is the cover: Edited October 14, 200816 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263320 Share on other sites More sharing options...
October 14, 200816 yr Author comment_263322 WOW! Thanks for the info.Too bad those catalog are not online, I have 3 page of parts that was ordered for the car.Seem like it is a 260HP car. This is what it's mention on an evaluation appraisal.260HP was with triple Weber dcoe45 (Italy version) but I don't think I'm gonna keep these since I'm not familiar enough with carbs. This is a for a week end car. Not for racing. If I stay with my SU, would I loose a lot of HP?For your info, the motor is a L28 (don't know which one.... the vin have dissapear on the lock), E88 port and polish head with bigger valve, Racing springs, Cifford SS headers with Dual pipe, Perfomance ignition, don't know the spec of the cam. Racing oil pump, 7qt baffle oilpan, Oil cooler, ect.. The car was running on standard 94 octane gas. So don't the compression is too high for street use.Thanks for you help,Joce Link to comment https://www.classiczcars.com/forums/topic/29645-bob-sharp-racing-parts-catalogue/#findComment-263322 Share on other sites More sharing options...
