Email logins are now active ×
windshield wipers
rif222
Re posting. Windshield wipers on my 72 240 work,but not much difference between the 2 speeds. Slow. Linkage has been cleened and lubed. The wiper motor came out of a fairly low mieage car. Do you think the problem is in the motor or in the colum switch? Thanks. Bill.
I Had the same issue. I removed the wiper pivots from the car and disassembled them. Although they turned freely I was surprised at the amount of rust in them. I cleaned up the shafts on the wire brush and used a dremel with a wire brush on the bores. I reassembled with grease and the wipers worked like new.
Not as good as retrofitting a modern motor but a whole lot easier.
Derek
