October 14, 200816 yr Author comment_263328 Thanks, don't worry about it. Good news is I hooked all 3 lines up to the vac barb, and got the defrost to work, it blows hot air! However heat won't come out of the vents... no matter which setting it is on. If it is on Bi level, heat comes out defroster but cold air out the vents...What does this mean? A stuck heater 'door' or flap??Still runnin pretty rich, going to check the CTS, TTS, CTS, AAV,AFM once it stops raining.Thanks Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263328 Share on other sites More sharing options...
October 14, 200816 yr comment_263332 Can you take a picture of what you have done and post it. I am assuming that you are aware that thesome hoses tie onto the silver tubes adjacent the vacum storage bottle. Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263332 Share on other sites More sharing options...
October 14, 200816 yr comment_263334 That's more or less what I said........ Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263334 Share on other sites More sharing options...
October 14, 200816 yr comment_263337 Don't know if the system changed so much by the time it got to the 280's but the eyeball vents in the 240 are ONLY for fresh air. You'll never get heated air out of them unless it's an extremely warm day outside and your cowl bucket is hot.E Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263337 Share on other sites More sharing options...
October 14, 200816 yr comment_263338 E - they blow cold with AC.Sorry Stephen - missed your post. Edited October 14, 200816 yr by Sailor Bob Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263338 Share on other sites More sharing options...
October 14, 200816 yr comment_263341 Sailor Bob said: E - they blow cold with AC.Sorry Stephen - missed your post.Rick, I think you misundestood why I said that. I haven't worked much with the 280Z factory air (mine is aftermarket) but three lines coming from the one intake barb is not the correct hookup and likely why the mode doors aren't operating properly. The other lines pull from the magnet valves and the storage bottle. Splitting it three ways likely won't produce enough vacuum to open the doors. Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263341 Share on other sites More sharing options...
October 15, 200816 yr Author comment_263387 Ill get a pic ASAP guys, then maybe you'll get a better idea of what the deal is; But at least I get defrost hot air now!!!! Link to comment https://www.classiczcars.com/forums/topic/29651-a-few-simple-problems/?&page=2#findComment-263387 Share on other sites More sharing options...
