Posted October 20, 200816 yr comment_263850 where is the fuel relay located at. if anyone has a picture that will be great. Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/ Share on other sites More sharing options...
October 21, 200816 yr comment_263887 Above the ECU on the driver kick panel It has two squarish (6?) pin plugs that plug into it. The screw that holds its bracket down is real fun to remove.... Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-263887 Share on other sites More sharing options...
October 21, 200816 yr comment_263899 Above the ECU on the driver kick panel It has two squarish (6?) pin plugs that plug into it. The screw that holds its bracket down is real fun to remove....Unless it's a 78 in which case it's in the relay bracket under the hood. Edited October 21, 200816 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-263899 Share on other sites More sharing options...
October 22, 200816 yr Author comment_264061 the car is a 78 Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264061 Share on other sites More sharing options...
October 22, 200816 yr comment_264062 Edited October 22, 200816 yr by sblake01 Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264062 Share on other sites More sharing options...
October 22, 200816 yr Author comment_264063 under the hood where. looked for it but cant find it Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264063 Share on other sites More sharing options...
October 22, 200816 yr Author comment_264064 are they under the fusible links Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264064 Share on other sites More sharing options...
October 22, 200816 yr comment_264065 That's the box with the fusible links on it just in front of the battery. You have to open it up to get to the relays. Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264065 Share on other sites More sharing options...
October 22, 200816 yr Author comment_264113 i opened it but none of the relays match with fuel relay i bought Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264113 Share on other sites More sharing options...
October 22, 200816 yr comment_264116 You must have bought a 75-77 fuel injection relay. The one you need is to one with 6 terminals, to one farthest right in the picture. For a 78 the EFI main relay looks like this: And the 75-77 EFI main relay looks like this: Link to comment https://www.classiczcars.com/forums/topic/29717-fuel-relay-location/#findComment-264116 Share on other sites More sharing options...
