September 11, 20186 yr comment_557274 Hi everyone, According to some searches I have done the OEM tires for S30s in the USA were: Brand Model Width Ratio Rim Sidewall Diameter Circumference Revs/Mile Difference OEM 240z 175 82 14 5.65 25.30 79.48 797.18 0.00% OEM 280z 197 70 14 5.43 24.86 78.09 811.32 -1.77% I see above that Arne recommended around 825-840 revolutions per mile to keep the speedo accurate, but that doesn't match the math I have above, so either those aren't the right OEM tire sizes or those aren't the right RPM figures. I wonder if Arne's numbers come from pairing them with a different or a-typical transmission speedometer gear. I am putting together a spreadsheet of available tire sizes for 14 and 15" wheels and what to get this correct first. If you know of better threads with more or more accurate information, please reply,y with the link so that we can connect all of this and ensure that people don't go down the wrong path. I know this is a long dead thread, but in an effort to make sure that people are finding the best information possible, I wanted to push on some things said and verify what I have been finding in other places. Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557274 Share on other sites More sharing options...
September 11, 20186 yr comment_557296 2 hours ago, Matthew Abate said: Â Brand Model Width Ratio Rim Sidewall Diameter Circumference Revs/Mile Difference OEM 240z 175 82 14 5.65 25.30 79.48 797.18 0.00% OEM 280z 197 70 14 5.43 24.86 78.09 811.32 -1.77% Â I thought the 240Z OEM 175 R14's had a ratio of 78, not 82 and I thought the 280Z was 195/70 R14. See post's 13 and 14 in this thread. Edited September 11, 20186 yr by w3wilkes Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557296 Share on other sites More sharing options...
September 11, 20186 yr comment_557299 On 9/11/2018 at 12:02 PM, w3wilkes said: I thought the 240Z OEM 175 R14's had a ratio of 78, not 82 and I thought the 280Z was 195/70 R14. See post's 13 and 14 in this thread. That's helpful, thanks. I have found various places online that give 82% as the ratio for a 175sr14, but I guess I've seen 78% just as much, and Arne gives the ratio as 80% in that thread you posted. That 4% spread makes a huge difference in what options will work, though, so thanks. The 280Z size I have above came from Arne's post in this thread (#19): On 12/20/2008 at 9:28 PM, Arne said: The stock size for a 240Z was 175-14 … 197/70-14 (stock on 280Zs)… From what I understand is the195/70-14 is a common choice to replace the unavailable sizes, not the original size.  However, none of this solves the RPM question I had. Edited September 13, 20186 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557299 Share on other sites More sharing options...
September 11, 20186 yr comment_557300 Other than that post by @Arne I've only seen 195/70 R14 listed for a 280Z http://www.automobile-catalog.com/tire/1978/2104790/datsun_280_z.html Then using the Discount Tire size calculator and comparing the 195/70 R14 to a 175/78 R14 the RPM's are identical https://www.discounttire.com/learn/tire-size-calculator I run 205/60 R15 which comes out to a 2 RPM difference from what I believe is stock tire size using the Discount Tire size calculator. Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557300 Share on other sites More sharing options...
September 13, 20186 yr comment_557452 Right, but several tire retailers list the sidewall ratio of a 175HR14 at 82%, which is 0.55 inches larger in diameter and throws the equation quite significantly.  All of these sites have something that supports the 175HR14 sidewall ratio being 82%. https://www.moderntiredealer.com/article/311243/understanding-tire-dimensions https://en.wikipedia.org/wiki/Tire_code https://www.tirerack.com/tires/tiretech/45_conversionchart.jsp (see 1960 to present EURO-METRIC column) https://www.utires.com/articles/buying-tires-guide-tire-numbers-mean/ https://www.errolstyres.co.za/odcalculator https://www.denniskirk.com/learn/tire-sizes-explained  If it was 82%, then a 195/70-14 is 0.95 inches smaller in diameter and additional RPM.  Ultimately, though, I'm not trying to argue whether people should get 195/70-14s or not. I'm more interested in all the other sizes and which ones are good choices, particularly for 15" rims, but also 16s. Edited September 13, 20186 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557452 Share on other sites More sharing options...
September 13, 20186 yr comment_557464 I found 175 HR 14s for sale:Â https://www.longstonetyres.co.uk/175hr14-michelin-xas.htmlThese are 634mm, which makes the ratio for the sidewall 79.542857142%So Arne was right according to this tire. Edited September 13, 20186 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557464 Share on other sites More sharing options...
September 13, 20186 yr comment_557465 I put together a spreadsheet for 14 to 16" wheels that I hope does a better job of illustrating why I think this question of 175HR14 sidewall-ratio accuracy is important if you want speedometer accuracy. Width Ratio Rim Side Diam. Circ. R/Mi Δ Width Range 175  14 5.51 25.02 78.61 805.96 N/A 4.5 - 5 197 70 14 5.43 24.86 78.09 811.32 -0.67% 6 175 50 14 3.44 20.89 65.63 965.45 -19.79% 5 - 5.5 175 55 14 3.79 21.58 67.79 934.63 -15.96% 5 - 5.5 175 60 14 4.13 22.27 69.96 905.71 -12.38% 5 - 5.5 175 65 14 4.48 22.96 72.12 878.53 -9.00% 5 - 5.5 175 70 14 4.82 23.65 74.29 852.93 -5.83% 5 - 5.5 175 75 14 5.17 24.33 76.45 828.78 -2.83% 5 - 5.5 175 80 14 5.51 25.02 78.61 805.96 0.00% 5 - 5.5 185 50 14 3.64 21.28 66.86 947.60 -17.57% 5.5 - 6 185 55 14 4.01 22.01 69.15 916.24 -13.68% 5.5 - 6 185 60 14 4.37 22.74 71.44 886.89 -10.04% 5.5 - 6 185 65 14 4.73 23.47 73.73 859.37 -6.63% 5.5 - 6 185 70 14 5.10 24.20 76.02 833.50 -3.42% 5.5 - 6 185 75 14 5.46 24.93 78.30 809.15 -0.39% 5.5 - 6 185 80 14 5.83 25.65 80.59 786.17 2.46% 5.5 - 6 195 50 14 3.84 21.68 68.10 930.39 -15.44% 6 - 6.5 195 55 14 4.22 22.44 70.51 898.56 -11.49% 6 - 6.5 195 60 14 4.61 23.21 72.92 868.84 -7.80% 6 - 6.5 195 65 14 4.99 23.98 75.34 841.03 -4.35% 6 - 6.5 195 70 14 5.37 24.75 77.75 814.94 -1.11% 6 - 6.5 195 75 14 5.76 25.52 80.16 790.42 1.93% 6 - 6.5 195 80 14 6.14 26.28 82.57 767.33 4.79% 6 - 6.5 205 50 14 4.04 22.07 69.34 913.79 -13.38% 6.5 - 7 205 55 14 4.44 22.88 71.87 881.55 -9.38% 6.5 - 7 205 60 14 4.84 23.69 74.41 851.51 -5.65% 6.5 - 7 205 65 14 5.25 24.49 76.94 823.45 -2.17% 6.5 - 7 205 70 14 5.65 25.30 79.48 797.18 1.09% 6.5 - 7 205 75 14 6.05 26.11 82.02 772.54 4.15% 6.5 - 7 205 80 14 6.46 26.91 84.55 749.37 7.02% 6.5 - 7 215 50 14 4.23 22.46 70.57 897.77 -11.39% 7 - 7.5 215 55 14 4.66 23.31 73.23 865.17 -7.35% 7 - 7.5 215 60 14 5.08 24.16 75.89 834.86 -3.59% 7 - 7.5 215 65 14 5.50 25.00 78.55 806.60 -0.08% 7 - 7.5 215 70 14 5.93 25.85 81.21 780.19 3.20% 7 - 7.5 215 75 14 6.35 26.70 83.87 755.45 6.27% 7 - 7.5 215 80 14 6.77 27.54 86.53 732.23 9.15% 7 - 7.5 225 50 14 4.43 22.86 71.81 882.31 -9.47% 7.5 - 8 225 55 14 4.87 23.74 74.59 849.39 -5.39% 7.5 - 8 225 60 14 5.31 24.63 77.38 818.85 -1.60% 7.5 - 8 225 65 14 5.76 25.52 80.16 790.42 1.93% 7.5 - 8 225 70 14 6.20 26.40 82.94 763.90 5.22% 7.5 - 8 225 75 14 6.64 27.29 85.73 739.10 8.30% 7.5 - 8 225 80 14 7.09 28.17 88.51 715.86 11.18% 7.5 - 8 235 50 14 4.63 23.25 73.05 867.37 -7.62% 8 - 8.5 235 55 14 5.09 24.18 75.95 834.18 -3.50% 8 - 8.5 235 60 14 5.55 25.10 78.86 803.43 0.31% 8 - 8.5 235 65 14 6.01 26.03 81.77 774.88 3.86% 8 - 8.5 235 70 14 6.48 26.95 84.67 748.28 7.16% 8 - 8.5 235 75 14 6.94 27.88 87.58 723.44 10.24% 8 - 8.5 235 80 14 7.40 28.80 90.49 700.21 13.12% 8 - 8.5 245 50 14 4.82 23.65 74.29 852.93 -5.83% 8.5 - 9 245 55 14 5.31 24.61 77.32 819.50 -1.68% 8.5 - 9 245 60 14 5.79 25.57 80.35 788.59 2.16% 8.5 - 9 245 65 14 6.27 26.54 83.38 759.93 5.71% 8.5 - 9 245 70 14 6.75 27.50 86.41 733.28 9.02% 8.5 - 9 245 75 14 7.23 28.47 89.44 708.44 12.10% 8.5 - 9 245 80 14 7.72 29.43 92.47 685.22 14.98% 8.5 - 9 185 50 15 3.64 22.28 70.01 905.07 -12.30% 5.5 - 6 185 55 15 4.01 23.01 72.29 876.42 -8.74% 5.5 - 6 185 60 15 4.37 23.74 74.58 849.54 -5.41% 5.5 - 6 185 65 15 4.73 24.47 76.87 824.25 -2.27% 5.5 - 6 185 70 15 5.10 25.20 79.16 800.42 0.69% 5.5 - 6 185 75 15 5.46 25.93 81.45 777.93 3.48% 5.5 - 6 185 80 15 5.83 26.65 83.73 756.68 6.12% 5.5 - 6 195 50 15 3.84 22.68 71.24 889.36 -10.35% 6 - 6.5 195 55 15 4.22 23.44 73.65 860.24 -6.73% 6 - 6.5 195 60 15 4.61 24.21 76.07 832.96 -3.35% 6 - 6.5 195 65 15 4.99 24.98 78.48 807.36 -0.17% 6 - 6.5 195 70 15 5.37 25.75 80.89 783.29 2.81% 6 - 6.5 195 75 15 5.76 26.52 83.30 760.61 5.63% 6 - 6.5 195 80 15 6.14 27.28 85.71 739.21 8.28% 6 - 6.5 205 50 15 4.04 23.07 72.48 874.18 -8.46% 6.5 - 7 205 55 15 4.44 23.88 75.01 844.63 -4.80% 6.5 - 7 205 60 15 4.84 24.69 77.55 817.02 -1.37% 6.5 - 7 205 65 15 5.25 25.49 80.09 791.15 1.84% 6.5 - 7 205 70 15 5.65 26.30 82.62 766.87 4.85% 6.5 - 7 205 75 15 6.05 27.11 85.16 744.04 7.68% 6.5 - 7 205 80 15 6.46 27.91 87.69 722.52 10.35% 6.5 - 7 215 50 15 4.23 23.46 73.72 859.51 -6.64% 7 - 7.5 215 55 15 4.66 24.31 76.38 829.59 -2.93% 7 - 7.5 215 60 15 5.08 25.16 79.03 801.67 0.53% 7 - 7.5 215 65 15 5.50 26.00 81.69 775.58 3.77% 7 - 7.5 215 70 15 5.93 26.85 84.35 751.13 6.80% 7 - 7.5 215 75 15 6.35 27.70 87.01 728.17 9.65% 7 - 7.5 215 80 15 6.77 28.54 89.67 706.58 12.33% 7 - 7.5 225 50 15 4.43 23.86 74.95 845.33 -4.88% 7.5 - 8 225 55 15 4.87 24.74 77.74 815.07 -1.13% 7.5 - 8 225 60 15 5.31 25.63 80.52 786.90 2.37% 7.5 - 8 225 65 15 5.76 26.52 83.30 760.61 5.63% 7.5 - 8 225 70 15 6.20 27.40 86.08 736.02 8.68% 7.5 - 8 225 75 15 6.64 28.29 88.87 712.97 11.54% 7.5 - 8 225 80 15 7.09 29.17 91.65 691.32 14.22% 7.5 - 8 235 50 15 4.63 24.25 76.19 831.61 -3.18% 8 - 8.5 235 55 15 5.09 25.18 79.10 801.05 0.61% 8 - 8.5 235 60 15 5.55 26.10 82.00 772.65 4.13% 8 - 8.5 235 65 15 6.01 27.03 84.91 746.21 7.41% 8 - 8.5 235 70 15 6.48 27.95 87.82 721.51 10.48% 8 - 8.5 235 75 15 6.94 28.88 90.72 698.39 13.35% 8 - 8.5 235 80 15 7.40 29.80 93.63 676.71 16.04% 8 - 8.5 245 50 15 4.82 24.65 77.43 818.32 -1.53% 8.5 - 9 245 55 15 5.31 25.61 80.46 787.50 2.29% 8.5 - 9 245 60 15 5.79 26.57 83.49 758.92 5.84% 8.5 - 9 245 65 15 6.27 27.54 86.52 732.34 9.14% 8.5 - 9 245 70 15 6.75 28.50 89.55 707.56 12.21% 8.5 - 9 245 75 15 7.23 29.47 92.58 684.40 15.08% 8.5 - 9 245 80 15 7.72 30.43 95.61 662.70 17.77% 8.5 - 9 255 40 15 4.02 23.03 72.36 875.68 -8.65% 9 - 9.5 255 45 15 4.52 24.04 75.51 839.10 -4.11% 9 - 9.5 255 50 15 5.02 25.04 78.66 805.46 0.06% 9 - 9.5 255 55 15 5.52 26.04 81.82 774.41 3.92% 9 - 9.5 255 60 15 6.02 27.05 84.97 745.66 7.48% 9 - 9.5 255 65 15 6.53 28.05 88.13 718.98 10.79% 9 - 9.5 255 70 15 7.03 29.06 91.28 694.13 13.88% 9 - 9.5 265 40 15 4.17 23.35 73.35 863.86 -7.18% 9.5 - 10 265 45 15 4.69 24.39 76.62 826.91 -2.60% 9.5 - 10 265 50 15 5.22 25.43 79.90 792.99 1.61% 9.5 - 10 265 55 15 5.74 26.48 83.18 761.74 5.49% 9.5 - 10 265 60 15 6.26 27.52 86.46 732.86 9.07% 9.5 - 10 265 65 15 6.78 28.56 89.73 706.09 12.39% 9.5 - 10 265 70 15 7.30 29.61 93.01 681.21 15.48% 9.5 - 10 275 40 15 4.33 23.66 74.33 852.36 -5.76% 10 - 10.5 275 45 15 4.87 24.74 77.74 815.07 -1.13% 10 - 10.5 275 50 15 5.41 25.83 81.14 780.90 3.11% 10 - 10.5 275 55 15 5.95 26.91 84.54 749.48 7.01% 10 - 10.5 275 60 15 6.50 27.99 87.94 720.49 10.60% 10 - 10.5 275 65 15 7.04 29.07 91.34 693.66 13.93% 10 - 10.5 275 70 15 7.58 30.16 94.74 668.76 17.02% 10 - 10.5 185 40 16 2.91 21.83 68.57 924.01 -14.65% 5.5 - 6 185 45 16 3.28 22.56 70.86 894.17 -10.94% 5.5 - 6 185 50 16 3.64 23.28 73.15 866.20 -7.47% 5.5 - 6 185 55 16 4.01 24.01 75.44 839.92 -4.21% 5.5 - 6 185 60 16 4.37 24.74 77.72 815.20 -1.15% 5.5 - 6 185 65 16 4.73 25.47 80.01 791.88 1.75% 5.5 - 6 185 70 16 5.10 26.20 82.30 769.87 4.48% 5.5 - 6 195 40 16 3.07 22.14 69.56 910.86 -13.02% 6 - 6.5 195 45 16 3.45 22.91 71.97 880.34 -9.23% 6 - 6.5 195 50 16 3.84 23.68 74.38 851.80 -5.69% 6 - 6.5 195 55 16 4.22 24.44 76.80 825.04 -2.37% 6 - 6.5 195 60 16 4.61 25.21 79.21 799.92 0.75% 6 - 6.5 195 65 16 4.99 25.98 81.62 776.28 3.68% 6 - 6.5 195 70 16 5.37 26.75 84.03 754.00 6.45% 6 - 6.5 205 40 16 3.23 22.46 70.55 898.09 -11.43% 6.5 - 7 205 45 16 3.63 23.26 73.09 866.93 -7.56% 6.5 - 7 205 50 16 4.04 24.07 75.62 837.86 -3.96% 6.5 - 7 205 55 16 4.44 24.88 78.16 810.68 -0.59% 6.5 - 7 205 60 16 4.84 25.69 80.69 785.21 2.58% 6.5 - 7 205 65 16 5.25 26.49 83.23 761.29 5.54% 6.5 - 7 205 70 16 5.65 27.30 85.76 738.78 8.34% 6.5 - 7 215 40 16 3.39 22.77 71.54 885.67 -9.89% 7 - 7.5 215 45 16 3.81 23.62 74.20 853.93 -5.95% 7 - 7.5 215 50 16 4.23 24.46 76.86 824.38 -2.29% 7 - 7.5 215 55 16 4.66 25.31 79.52 796.81 1.14% 7 - 7.5 215 60 16 5.08 26.16 82.18 771.03 4.33% 7 - 7.5 215 65 16 5.50 27.00 84.84 746.86 7.33% 7 - 7.5 215 70 16 5.93 27.85 87.49 724.16 10.15% 7 - 7.5 225 40 16 3.54 23.09 72.53 873.58 -8.39% 7.5 - 8 225 45 16 3.99 23.97 75.31 841.30 -4.38% 7.5 - 8 225 50 16 4.43 24.86 78.09 811.32 -0.67% 7.5 - 8 225 55 16 4.87 25.74 80.88 783.41 2.80% 7.5 - 8 225 60 16 5.31 26.63 83.66 757.35 6.03% 7.5 - 8 225 65 16 5.76 27.52 86.44 732.97 9.06% 7.5 - 8 225 70 16 6.20 28.40 89.23 710.11 11.89% 7.5 - 8 235 40 16 3.70 23.40 73.52 861.83 -6.93% 8 - 8.5 235 45 16 4.16 24.33 76.42 829.05 -2.86% 8 - 8.5 235 50 16 4.63 25.25 79.33 798.67 0.90% 8 - 8.5 235 55 16 5.09 26.18 82.24 770.45 4.41% 8 - 8.5 235 60 16 5.55 27.10 85.14 744.15 7.67% 8 - 8.5 235 65 16 6.01 28.03 88.05 719.58 10.72% 8 - 8.5 235 70 16 6.48 28.95 90.96 696.59 13.57% 8 - 8.5 245 40 16 3.86 23.72 74.51 850.38 -5.51% 8.5 - 9 245 45 16 4.34 24.68 77.54 817.15 -1.39% 8.5 - 9 245 50 16 4.82 25.65 80.57 786.41 2.43% 8.5 - 9 245 55 16 5.31 26.61 83.60 757.91 5.96% 8.5 - 9 245 60 16 5.79 27.57 86.63 731.40 9.25% 8.5 - 9 245 65 16 6.27 28.54 89.66 706.68 12.32% 8.5 - 9 245 70 16 6.75 29.50 92.69 683.57 15.19% 8.5 - 9 255 40 16 4.02 24.03 75.50 839.24 -4.13% 9 - 9.5 255 45 16 4.52 25.04 78.65 805.58 0.05% 9 - 9.5 255 50 16 5.02 26.04 81.81 774.52 3.90% 9 - 9.5 255 55 16 5.52 27.04 84.96 745.77 7.47% 9 - 9.5 255 60 16 6.02 28.05 88.11 719.08 10.78% 9 - 9.5 255 65 16 6.53 29.05 91.27 694.23 13.86% 9 - 9.5 255 70 16 7.03 30.06 94.42 671.04 16.74% 9 - 9.5 265 40 16 4.17 24.35 76.49 828.38 -2.78% 9.5 - 10 265 45 16 4.69 25.39 79.76 794.34 1.44% 9.5 - 10 265 50 16 5.22 26.43 83.04 762.99 5.33% 9.5 - 10 265 55 16 5.74 27.48 86.32 734.02 8.93% 9.5 - 10 265 60 16 6.26 28.52 89.60 707.16 12.26% 9.5 - 10 265 65 16 6.78 29.56 92.87 682.21 15.35% 9.5 - 10 265 70 16 7.30 30.61 96.15 658.95 18.24% 9.5 - 10 275 40 16 4.33 24.66 77.48 817.80 -1.47% 10 - 10.5 275 45 16 4.87 25.74 80.88 783.41 2.80% 10 - 10.5 275 50 16 5.41 26.83 84.28 751.79 6.72% 10 - 10.5 275 55 16 5.95 27.91 87.68 722.63 10.34% 10 - 10.5 275 60 16 6.50 28.99 91.08 695.64 13.69% 10 - 10.5 275 65 16 7.04 30.07 94.48 670.60 16.80% 10 - 10.5 275 70 16 7.58 31.16 97.88 647.30 19.69% 10 - 10.5 Edited September 13, 20186 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557465 Share on other sites More sharing options...
September 13, 20186 yr comment_557466 Seriously nice work! I thinks lots of folks will appreciate this. Perhaps it should be added to the technical library. Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557466 Share on other sites More sharing options...
September 13, 20186 yr comment_557474 Matthew many thanks for thr research thats one of the best charts ive seen concerning side dia. FWIW I have 185/70'S on shelby cal 500's i dont like them sidewall too short but came on the car when i bought it an are still like new so once they wear ill go to a different size i like the look of the 70's tires tall side walls Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557474 Share on other sites More sharing options...
September 14, 20186 yr comment_557489 Using a set of Falken / Ziex a size smaller than stock. Car sits a little lower due to the tires. 130 MPH speed rating, good in the rain. Tires with a high speed rating wear out a little faster, seems like a bad gamble to go with lower speed rating though. I went smaller to get a faster time at the strip, although I haven't raced it since installing them. Feels a lot faster off the line and 40 to 90 MPH for freeway on ramps. Speedo optimistic per table, but I don't care. Bigger motor now so maybe I'd get a quicker ET and/or faster top speed in 1/4 mile by going back to stock diameter, don't know though, lots of variables. Guess that's a question for a different thread. Main thing is get good tires. H rating or above. Bought some Enterprise cheapies when was broke. Scary in the rain, also one blew out on the freeway. It was fairly new. Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557489 Share on other sites More sharing options...
September 14, 20186 yr comment_557498 Great info in that table! Edited September 14, 20186 yr by Zup Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557498 Share on other sites More sharing options...
September 14, 20186 yr comment_557499 Matthew, thanks for producing that awesome chart, it is very useful. For reference I just measured the lightly used original spare from my 7'70 car, its a Bridgestone 175SR14. Using a Pi tape I measured the existing outside diameter at 25.17" and a tread depth of 7/32". Calculates to just over an 81% aspect ratio, right in the middle of that 80 - 82 range. Cheers Mike Link to comment https://www.classiczcars.com/forums/topic/29719-best-performance-tire-for-a-70-240z/?&page=3#findComment-557499 Share on other sites More sharing options...
