Posted October 26, 200816 yr comment_264514 Is this what I would need to do a vaccum pressure test on my 1975 280Z? This is at sears? Here is what it says:"Fine tunes carburetion and timing peak for maximum fuel economy. Easy-to-read, 3-1/2 diameter face displays 0-30 inches vacuum and 0-10 pounds of pressure. Complete with hose and adapters.Fuel pump pressure. Mechanical condition of the engine. Vacuum control system function. For leaks in the intake manifold, manifold and head gaskets, piston rings, valves and vacuum lines."Is this the right tool? Please advise..Thanks Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/ Share on other sites More sharing options...
October 26, 200816 yr comment_264519 Exactly what is it that you're trying to test? Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264519 Share on other sites More sharing options...
October 27, 200816 yr Author comment_264529 can vaccum be measured? Wouldn't it tell me if there are leaks in the system or even how the engine condition might be, besides a compression test? Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264529 Share on other sites More sharing options...
October 27, 200816 yr comment_264532 A vacuum gauge would be more useful on a carbureated car than it would on an EFI car. It would tell you if there are leaks, if you know what the test vacuum reading should be, but there isn't any thing that you'd adjust based on vacuum readings on an EFI car. Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264532 Share on other sites More sharing options...
October 27, 200816 yr comment_264541 Vac. ga. tests upper engine stuff, like valves and certain vac. leaks. Its the poor man's diagnostic machine. Use it for non-blown engines as a very easy tester. Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264541 Share on other sites More sharing options...
October 27, 200816 yr comment_264557 I have one and I know how it's used but a compression tester, a multimeter, and a fuel pressure tester would be more useful with the Datsun 75-84 EFI systems. Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264557 Share on other sites More sharing options...
October 27, 200816 yr Author comment_264576 Thanks Gents. I then will pass on buying that equipment. I appreciate your input. Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264576 Share on other sites More sharing options...
October 27, 200816 yr comment_264644 A vacuum gauge would be more useful on a carbureated car than it would on an EFI car. It would tell you if there are leaks, if you know what the test vacuum reading should be, but there isn't any thing that you'd adjust based on vacuum readings on an EFI car.I disagree. A vacuum gauge is useful on any car. A vacuum leak will wreak havoc with both an EFI and carbureuted car.How do you know how much vacuum you are pulling at idle? Worn rings, valve seals, valve lash, intake manifold leak, loose clamps, cracked/missing hoses, will affect vacuum. A vacuum leak caused by a cracked hose or missing clamp will cause a car to run lean (unmetered air). Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264644 Share on other sites More sharing options...
October 28, 200816 yr comment_264670 Vacuum leaks are easy enough to find w/o a guage. Especially extrenal ones. I'm considering average skills here. What the guage will show and what to do about it are different kettles of fish alltoghther. I know how to use a vacuum guage as I said in post 6. For someone who unfamiliar with it's use it will just cause more confusion. Link to comment https://www.classiczcars.com/forums/topic/29787-actron-vacuum-pressure-tester-kit/#findComment-264670 Share on other sites More sharing options...
