Posted October 30, 200816 yr comment_264876 I would be interested in seeing photos of audio system upgrades and integration with a description of the components.Thanks,Fixitman Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/ Share on other sites More sharing options...
October 30, 200816 yr comment_264888 Hiya fixitman,We have a categorized photo gallery here with a folder called stereo systems. Check out the gallery from the main menu or just click on my link below:http://www.classiczcars.com/photopost/index.php?cat=1If you don't find any in there, just do a search for audio, stereo, speakers, etc...Let me know what you think!Mike Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264888 Share on other sites More sharing options...
October 30, 200816 yr comment_264891 Probably not all that helpful, Mike. There's only 2 photos in there!!Fixitman, I'm going to assume you are interested in modern ICE? Not old vintage stuff like I have. If so, you may want to send a PM to Zs-ondabrain as he does this kind of thing for a living, and has done several 240Zs. He'll know what fits, and where to put it all. Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264891 Share on other sites More sharing options...
October 30, 200816 yr comment_264892 I don't have any pictures handy, but in my '78, I have an Alpine 9886 headunit, 4" Boston Accoustic speakers in the factory spots under the 1/4 windows, two Alpine amps under the wood deck, and a Sony crossover under the deck as well. I still need to pick up a rear speaker box and get two 6x9's. I love the headunit. I have a 4Gb USB flash drive hooked to it to house my music. I hate the heavy wood flase floor in the '77-'78 cars, but it does make for easy stereo component installation. The components are out of sight and protected from cargo. Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264892 Share on other sites More sharing options...
October 30, 200816 yr comment_264896 I've got a Sony CDXGT-720 head unit, an MTX Audio 4-channel 800W TE404 Thunder Elite amplifier, a set of Polk Audio db series 6x9's and Polk Audio db series 5 1/4" component speakers with external tweeters and crossovers. My head unit is in the factory location, my amp is behind the driver's seat, the components are in the doors, tweeters in the kick panels and 6x9s are in the MSA rear hatch box. Here are some preliminary install photos. BTW, Z's-ondabrain helped with the install. Edited October 30, 200816 yr by JonnyRock Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264896 Share on other sites More sharing options...
October 31, 200816 yr comment_264932 Pioneer three-way 6x9s in the tool compartments. I sealed the lids and installed sound deadener under the lids and in the compartments. Alpine two-way 6-in. with directional tweeter in custom enclosures I made in the kick panels. MB Quart tweeters in the side vents. I just attached them to the vent and did not cut the vent itself. Performance Technique 1000 watt 4-channel amplifier. It is located behind the passenger seat. Dual head unit with Bluetooth, Auxiliary input (as seen by the cable) and USB input. Bazooka powered subwoofer. The spare tire well is where I am going to relocate my battery with a Braille battery. The system has some serious thump. The bass is tight (not as tight as running a better sub) and the highs come in clear with the tweeters and Alpines. The two switches you see under the head unit are functional. The top switch allows me to switch between maps on my engine management system (100 octane and 91 octane tunes). The lower switch is the power window switch from a 1994 Maxima. I've wired it up to control my 280zx power mirrors. Edited October 31, 200816 yr by ktm Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264932 Share on other sites More sharing options...
October 31, 200816 yr comment_264933 HELPED!!! HELPED!!! Is that all I get? HELPED.Just screwin with ya John.Hey Mike, I'm gonna load a bunch into the Audio Systems file.I don't think we had that when I uploaded all my stuff.Fixitman..... What do you have in mind? I have 2) 10" MTX subs in a custom fiberglass box in the spare tire well, 2) 400 watt amps behind the seats, 1) 4-ch to the 6 speakers 1) 2-ch to the subs2) 5 1/4" 2-ways in the stock rear location2) 4" Kicker 2-ways in the doors2) 6" Alpine 2-ways in custom fiberglass pods in the front kick panel area1) Pioneer AM/FM/CD/XM Satelite Radio head unit.1) Hidden DVD player with headphones1) 7" Monitor under the Pass. side dash, that flips out for viewing2 guage power wire on the battery to the (-) ground bolt and to the 4-fuse distribution block on the firewall. and 4 guage to the amps.1) custom grounding kit w/ gold plated connectors and terminals that I made cause Z's really need it. Full alarm, power windows, power door locks, H4 lights, LED taillights-front markers-side markers-dash lights-map lights, Cold cathode dome lights and under dash lights, and the list goes on.I'll upload some stuff soooooon, I promise.Dave.*EDIT* I just uploaded a bunch and should show up as soon as they are processed. Edited October 31, 200816 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264933 Share on other sites More sharing options...
October 31, 200816 yr comment_264938 HELPED!!! HELPED!!! Is that all I get? HELPED.Just screwin with ya Jon ALRIGHT, ALRIGHT. You got me. Dave did like 98% of the install, so technically I helped. I... I... I just wanted to be one of the cool kids for once Dave! Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264938 Share on other sites More sharing options...
October 31, 200816 yr comment_264940 ALRIGHT, ALRIGHT. You got me. Dave did like 98% of the install, so technically I helped.I... I... I just wanted to be one of the cool kids for once Dave! We'll call it 70/30 and don't worry, you are one of the "Cool Kids", after all, YOU DO OWN A 240Z. duh. Dave. Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264940 Share on other sites More sharing options...
October 31, 200816 yr comment_264990 Probably not all that helpful, Mike. There's only 2 photos in there!!Bummer!! Guys put your photos in the gallery, too! I'll have to put some photos of mine in there too. Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-264990 Share on other sites More sharing options...
October 31, 200816 yr comment_265002 I put 12 in there last night. I know John has at least 8? he can put in. Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-265002 Share on other sites More sharing options...
October 31, 200816 yr comment_265038 The timing is perfect on this as I'm getting ready to upgrade my amp and add some front speakers.Right now I have 2 6x9s in the back in custom enclosures. I plan on adding 2 4" 2 way speakers in the front kick panels. I'm not running a head unit as I'm putting together a carputer with a 7" touch screen. I'm only going to have 2 channel output with a Griffin DAC. I was planning on running a 4 channel amp with some built in filtering. I'm thinking something along these lineshttp://www.crutchfield.com/p_489AP740/Profile-AP740.html?tp=115I'm not going to buy from Crutchfield as they're kind of pricy.Any thoughts on this combo?ThanksDerek Link to comment https://www.classiczcars.com/forums/topic/29817-audio-systems/#findComment-265038 Share on other sites More sharing options...
