Hello Guys ^_^
I need help with the parts numbers for 2 oil pumps and 1 fuel pump.
I found a Nismo "High Velocity Oil Pump" that flows 15% more oil and
also a "High Preasure Fuel Pump at 90 psi"
Like to know the part numbers for those 2 pumps so I can order the correct one for my 1977 280Z.
I'm not sure but I assume the oil pumps are all the same as it's qouted as
being for the L6 engine.
Also any Nismo part numbers for the Fuel Pumps aswell or at least the last
number they were issued.
Please call me at my parts store number at 530-301-1562 if I'm
not online cause I need order the oil pump and fuel pump ASAP!
Thyanx ~Z~
The high volume oil pump is 15010-S8000 and the competition oil pump is 15010-A1100. As far as I know, Nissan has never made a competition or high volume fuel pump for the EFI engines. They raced them with carbs and the high volume fuel pump they list is for carbed cars. The stock EFI fuel pump will put out more than enough pressure. Remember, it's regulated. If you want or need higher fuel pressure you need a rising rate fuel pressure regulator which is available through many places including MSA.
http://www.thezstore.com/page/TZS/PROD/PFFC14/11-3073
Edited by sblake01
Thaynx Blake!
New part number for 15010-S8000 is 15010-F800A.
The competition oil pump number 15010-A1100 came back as
a never used number.
Don't know if this is true or not or if the number has a typo.
15010-F800A is a $172.00 part by the way and does flow 15% more oil.
The fuel pump (what everr Part# it may be) is suddenly not in the
system, but then again I was never told if it was for 280Z or not.
But knowing your knowledge is far greater than mine :smoke: 280Z was
not the case.
But in any event the fuel pump turns up NLA at least searching without
the part number
Also how about the Nismo front and rear sway bars numbers?
Essentialy thats the last part I need on my parts list to finsish off old
Ruby Girl :bandit:
~Z~
Nissan comp numbers don't necessarily show in a regular Nissan database. Like I said, there is no Nissan comp EFI fuel pump. They one they show is for carbed cars. You could use the L28ET oil pump-15010-V0300.
As far as the sway bars:
Ohhhhhh SNAP ! Freakin Sweet Bro, Thyanx !
I got one of the part numbers for Hybrdz to go through for the rear sway bar but
it came back made from Suspension Techniques.
Have placed a bid on Nismo Sway Bar Busings though on ebay for 5 bucks and
fits 1973-1978 Datsun 240z, 260z & 280z, 22mm and another 7/8" front or rear.
55617-E7210 and 54617-xxxxx
~Z~
Edited by WingZr0
Your catalog might be newer...mine is from 1997:embarrass: I've got turbo oil pumps in my Z and my 810...directly from the junkyard.
You lucky guy you :bandit:
All the Z's in my yards are stock!
LOL yeah it is from 2007
Yo, were can I order a copy?
I did get lucky. There were actually two ZXT's in the junkyard on the same day about 2 years ago when I bought my oil pumps. I've seen a few others since then.
  • Who's Online   1 Member, 0 Anonymous, 37 Guests (See full list)
