I discovered that the ground associated with the Combo switch was intermittant.
If I wiggled the wire I could get the lights to work.... I replaced the connector
on the black ground wire on the combo switch.... Life is better...
I am still having rear turn signal issues.... My fron turn signals work fine.
I'm going back to the harness connectors on the passenger side of the dash.
Jay
Not jus a Z - ZDisease
