Recently Browsing 0
Well, after many long years I have finally finished uni and have some time to start working on the Z again. However Since it was disassembled some parts have become mixed up with bits from the parts car(s), as it was all chucked into storage in a heap during a shed cleanup (when I wasnt finished). Id rather clean and paint the right parts first time round.
The car is a 73 240Z
The rear mousache bar, I have two types, one which is fairly straight, and one which has a sort of kink in it which would position the diff further forwards (all are from R180 Equiped cars) If it makes a difference, the rear suspension mount has a bit of a curve backwards in it, compared to the one in the parts manual which appears straight.
For the front diff mount/suspension mount for 73 should it be the one with a single large half found cut out in the bottom, or the one with a large on one side and a small on the other side? I know they arent facing the same way round in the pic, blonde moment, large cutout should be to the LHS
The crossmember at the front is a 240Z one isnt it
Rear suspension arms are all the same? Reason being some of the 240 ones had some dings and tears, so just going to use the best pair I had?
As a side note, when I took the car all apart, everything was photographed in detail etc, but that was all lost on a computer long ago, so this isnt going to be as easy as I hoped
.At least most of the smaller bits are baged and labeled.
Thanks Chris
Edited by Z Kid
https://www.classiczcars.com/forums/topic/29943-rear-suspension-components-73-240z/Share on other sites
