Newbie here, just acquired a really nice one owner '79 280ZX and I'm learning as much as I can. I have a nagging issue that if resolved, would make this car just a bit more enjoyable.
The ceiling dome light will illuminate with the manual switch on the assembly itself. It will illuminate as soon as soon as the hatch lever is pulled. The under dash courtesy lights will illuminate when either door is opened. I have pulled both the dome light assembly and the door switch. I have removed the inside pillar plastic cover and all three wires are plugged in and clean. The 3 pronged plug from the wire harness to the light assembly is firmly plugged in and clean. Based on what I have taken apart on this car, no one has ever messed with or repaired anything related to this issue as far as I can tell. I suspect the assembly is bad but because it works with the hatch, I question that theory. Is there a manual switch somewhere that kills the dome light that's hidden? Any ideas on how to resolve would be great. Thanks
https://www.classiczcars.com/forums/topic/29998-dome-light-in-a-79-280zx/
Recently Browsing 0
