Posted November 17, 200816 yr comment_266607 While I am waiting to hear back from the folks I bought my engine gasket set from I thought I would ask a question here. I took apart my oil pump to clean/inspect it and all seems fine. However I dont have the gasket that goes between the two halfs. The old one was thinner than your average gasket, (.005 in thick) Should this have been in my gasket set or is it a seperate item? Also, the body is steel, is this stock or should it be aluminum?It's on a 73. If I make my own will it have an effect in the rotor clearance? Link to comment https://www.classiczcars.com/forums/topic/30005-oil-pump-question/ Share on other sites More sharing options...
