November 19, 200816 yr comment_266804 Still a rookie - I get it now, but looking around I noticed there is no start date for the part in the microfiche, although it did show the change in 74 to the newer type. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266804 Share on other sites More sharing options...
November 19, 200816 yr comment_266805 Carl,Didn't the splash pans come on all S30's? I thought that was the case, but people often removed them and didn't put them back on. #237 still had its splash pan when I got it.-Mike Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266805 Share on other sites More sharing options...
November 19, 200816 yr comment_266813 Had me searching around - remember the thread about 0002. Check this out. Edited November 20, 200816 yr by Sailor Bob Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266813 Share on other sites More sharing options...
November 20, 200816 yr comment_266871 The only thing that bothers me is the auto trans. What are your thoughts on how this effects the value of the car? Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266871 Share on other sites More sharing options...
November 20, 200816 yr comment_266885 Carl,Didn't the splash pans come on all S30's? I thought that was the case, but people often removed them and didn't put them back on. #237 still had its splash pan when I got it.-MikeHi Mike.Here in North America, the splash pans came on most of the early Series I cars, but not all. They seem to have been deleted from the standard build for this market sometime in 1970. They returned later in the 1973 Model Year... after they started having hot weather running problems.I don't recall seeing any TSB that specified and end date for them, although it was common to see TSB's that announced any production changes.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266885 Share on other sites More sharing options...
November 20, 200816 yr comment_266888 The only thing that bothers me is the auto trans. What are your thoughts on how this effects the value of the car?Only about 12% of the 240-Z's sold in North America during 72/73 were A/T's. Add that to the mileage and you would have a pretty rare car. I think in this case the A/T would not have much of a negative effect.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266888 Share on other sites More sharing options...
November 20, 200816 yr comment_266889 I emailed the seller, and he replied that he had the splash pan for the car. In the ad he states that something has discolored one side of the shift lever - for such a low miles car, that and the door panel wrinkling seems odd. Maybe it sat outside for some time? Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266889 Share on other sites More sharing options...
November 20, 200816 yr comment_266894 Saying he has the splash pan "for" the car - is not the same as saying he has the splash pan "off" that car. I belleve the seller has or has had other 240-Z's.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266894 Share on other sites More sharing options...
November 20, 200816 yr comment_266929 Is that the correct air filter box for an early '73? The one I had on my car did not look like that at all? The passenger side door panel also looks damaged (has lots of wrinkles). Is that the tool pouch stuck at the edge of the carpet on the driver's side hatch area? It also seems to have lost it's splash pan. I'd be curious if that "siren" was dealer installed (and on the paperwork). Regardless, looks like it will need some cleanup and TLC!As Manny says, does anyone actually know this car and can verify it's authenticity? Hey Guys, I'm the owner of the car,and it has no damage or wrinkles anywhere. It's never been damaged and it's wearing 100% of it's original paint.I figured out how to use the macro setting on my camera,so here's a better picture of the speedo. I will be adding more pictures once I read the instruction manual to our camera and figure out why the pictures are turning out poorly. Regards, Jim Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266929 Share on other sites More sharing options...
November 21, 200816 yr comment_266954 Hey Guys,I'm the owner of the car,and it has no damage or wrinkles anywhere. It's never been damaged and it's wearing 100% of it's original paint.I figured out how to use the macro setting on my camera,so here's a better picture of the speedo. I will be adding more pictures once I read the instruction manual to our camera and figure out why the pictures are turning out poorly.Regards, JimLove the car Jim, It looks great. I own a 105k miles 73 automatic so I have something to compare it to. I hope it goes to a good home, good luck with the auction. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266954 Share on other sites More sharing options...
November 21, 200816 yr comment_266956 Only about 12% of the 240-Z's sold in North America during 72/73 were A/T's. Add that to the mileage and you would have a pretty rare car. I think in this case the A/T would not have much of a negative effect.FWIW,Carl B.I agree. This car is not likely to be sold to someone who intends to drive it, it is a collector or museum piece. For those uses, the condition is FAR more important than the equipment. Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266956 Share on other sites More sharing options...
November 21, 200816 yr comment_266992 If the Blue 71 with 66K miles is hitting the $14K mark already.. it will be interesting to see how the two finish at final bids.Yes, I am watching both, and if one of them stays in the "affordable" range for me (unfortunately not very likely as they are close to exceeding it now), I will be placing a bid! The tough part is deciding which one to get as I really like them both! Link to comment https://www.classiczcars.com/forums/topic/30013-check-out-this-all-original-73-on-fleabay/?&page=3#findComment-266992 Share on other sites More sharing options...
