Posted December 1, 200816 yr comment_267794 Hello!I am working on a '78 280z that my grandmother is selling. Currently it will start, run, and drive just fine, but only if I take a vacuum line off and put some gas in the manifold. Otherwise it just cranks. It's a fuel injected car.Anything that will point me in the right direction will be greatly appreciated. As I said, It's Granny's car, so I'm not very familiar with it (even though I love Z's).Thanks! Link to comment https://www.classiczcars.com/forums/topic/30125-78-280z-only-starts-with-starter-fluid/ Share on other sites More sharing options...
December 2, 200816 yr comment_267828 It could be losing fuel pressure due to a stuck injector or bad check valve. Will it restart once shut off while warm? When it does run, does it continue to run for long periods of time, or slowly run poorly and then die? We need more info. Link to comment https://www.classiczcars.com/forums/topic/30125-78-280z-only-starts-with-starter-fluid/#findComment-267828 Share on other sites More sharing options...
December 2, 200816 yr comment_267840 It could also be the cold start valve. Might wanna check that out. Link to comment https://www.classiczcars.com/forums/topic/30125-78-280z-only-starts-with-starter-fluid/#findComment-267840 Share on other sites More sharing options...
December 2, 200816 yr comment_267841 After you get it started, assuming that it runs properly at that point, and you get it up to operating temperature and turn it off, will it start again on it's own? If not you've got more issues than just a cold start valve. Like Jeff said, more info is needed. Link to comment https://www.classiczcars.com/forums/topic/30125-78-280z-only-starts-with-starter-fluid/#findComment-267841 Share on other sites More sharing options...
